I'm trying to locate an oil leak, and running into something funny. The oil pressure sender looks clean, but the knock sensor above it is covered in oil. I'm under the impression the knock sensor couldn't be leaking because it's just bolted to the outside of the block. Is it possible the pressure sender is leaking but nevertheless looks clean, and spitting oil onto the knock sensor above it? Or do I have another oil leak somewhere? Thanks for any advice.
