For my 2008 Mazda 5, this is almost correct. Thanks for the tip to pry near the window first! Trying to pry he "blades" at the bottom was not progressing as I hoped. In typical Mazda fashion, they make the simple things difficult and intricate. When I tried to turn the bulb socket, it didn't move. I first tried my fingers to no avail, then a pliers. To properly remove the bulb socket, one needs to stick a very small, thin flathead screwdriver (or toothpick?) along the outer edge of the tiny spring clip of each side before removing.
