Hi all, all is good in the world - but recently I did a hard run (rare) Thursday night, and on the following day to work on Friday, going to and from work, I heard this thrashing/metal scratching noise up front.
Any idea what it could be?
Oil levels are ok
Turned on/off AC, still intermittently happens
Mostly while moving, although the funny noises did happen at idle too (more often while moving)
This did happen after a semi hard run the night before... how do I know if my LSD is broken, are the symptoms similar?
Is there anything else I should look at?
Thanks,
~78K miles, stock
Oil levels are ok
Thanks,
~78K miles, stock
