CorkSport.com is MAZDA PERFORMANCE!
Results 1 to 15 of 15
Thread: Driver's side window auto-up/down issues
  1. #1
    VW_Defector MazdaTwo's Avatar
    2011 Mazda 2 Sport (Black)
    Join Date
    Nov 2010
    Location
    Joppatowne, MD
    Posts
    318
    Lately, I've noticed that I have intermittent operation of the automatic up/down feature on the driver's side window. It's (from what I can tell) completely random, and the only "common denominator" I can find is that it seems to happen when it's extremely hot outside.
    Probably the most annoying thing about it (besides the fact that it doesn't work) is that it's so inconsistent that I can't even justify scheduling a service appointment to get it checked.
    Has anyone else ever had this issue? I'm having flashbacks to my VW window regulator days... *eye starts to twitch*
  2. #2
    a member elfhearse's Avatar
    11 MX5 SE Dolphin Grey
    Join Date
    Dec 2003
    Location
    Lancaster, PA
    Posts
    291
    Same problem with me...just started working again today. I thought it started after I changed out my batteries (power interruption) but it could also be the hot weather. (Extreme cold = no radio sound, Extreme heat = no express window function 8)
    Previous Mazda's: 99 Miata 10AE, 03 Protege5, 11 Mazda2 Touring
  3. #3
    Registered Member matrixxx's Avatar
    mazda 2 2009 swap 1.6
    Join Date
    Aug 2009
    Location
    panama
    Posts
    274
    my problem is that no longer works in automatic
  4. #4
    Registered Member Domii3925's Avatar
    2011 Crystal White Pearl Mazda2 Sport
    Join Date
    Apr 2011
    Location
    Tewksbury, MA
    Posts
    151
    I actually had problems with putting the Passengers side window up with the button on the drivers side..... only once so far though! Weiiiird!
    15x7 +27 Kosei K1's SOLD
    205/50/15 Yokohoma S.drives SOLD
    Corksport Front Strut Bar SOLD
    Corksport Front Sway Bar
    Corksport Crankshaft Pulley SOLD
    Corksport Short Shift Plate SOLD
    Corksport Adjustable Struts SOLD
    H&R Lowering Springs SOLD
    Corksport Short Ram Intake SOLD
    Corksport Cold Air Duct SOLD
    Corksport Rear Torsion Bar SOLD
    Racing Beat Power Pulse Exhaust SOLD
    Pioneer Avic F700BT Navi SOLD
    Retrofit Kit with black housings SOLD
    OEM Foglight Kit w/ Switch
    http://piinkdem.blogspot.com/
  5. #5
    Mooz Mooz Mooz Richard_rsp's Avatar
    Donated: $22.22
    2016 Scion iA
    Join Date
    Jul 2006
    Location
    Atlanta, GA
    Posts
    206
    Quote Originally Posted by elfhearse View Post
    hmmm...
    I dont think its extreme heat. Ive been in 100+ degree weather every day for the past week plus several 104 degree days and I dont have any problem...
    Previous: 1992 Mazda Protege DX, 1989 Mazda RX-7, 1993 Mazda 323, 2001 Mazda MP3 #296, 2004 Mazdaspeed Miata MX-5, 2010 CX-7 iSV, 2011 Mazda2 Touring, 2010 Mazda MX-5 Touring, 2012 Mazda5 Sport (my lady's)
    Current: 2016 Scion iA (Mazda 2)
  6. #6
    Registered Member
    2011 Mazda2 Sport (Manual)
    Join Date
    Apr 2011
    Location
    USA
    Posts
    169
    One of my rear windows makes a electric whine type of noise when it first starts to roll down.
    I have window paranoia after owning a jeep liberty.
    There were famous for window regulator failures over & over & over.
  7. #7
    Registered Member XCLR8TN's Avatar
    2013 Fiat 500 Abarth
    Join Date
    May 2011
    Location
    Munroe Falls, OH
    Posts
    1,841
    Quote Originally Posted by Domii3925 View Post
    I've had this problem, I fixed it by putting the key back to the ignition/start position, then it worked. Like the driver side will go down/up on accessory but not the passenger side...
  8. #8
    Registered Member
    2011 Mazda Mazda2 Touring MT
    Join Date
    Jan 2011
    Location
    Poconos, PA
    Posts
    40
    I've been noticing some inconsistencies in the automatic function lately too...namely, if it starts going down on automatic, I used to be able to just click up and it would stop, now it seems to want to go down all the way, then I need to roll it back up if I only want it part way...not really a big deal, just means I don't use the automatic roll much anymore. I would venture to guess it's from the heat as well.
  9. #9
    Join Date
    Dec 2003
    Location
    Lancaster, PA
    Posts
    291
    I MAY have figured out how to get the drivers side back into AUTO mode when it decides to quit working. When I rolled the window up all the way, I held the switch down for ~3 seconds and the auto function worked after that.
  10. #10
    Registered Member
    2011 Mazda 2 Sport
    Join Date
    Mar 2011
    Location
    Orange County, CA
    Posts
    7
    I second elf... except what I've been doing is holding the driver's auto switch all the way up for a couple seconds. I've determined that there are times when the power windows act like the key is in the accessory position (I can't directly relate this to weather from what I've experienced). I'm guessing that there is a loose connection where the system receives the signal that the key is in the on position. I'm gonna try to get my hands on a wiring diagram to see if I can diagnose this myself without voiding the warranty.
  11. #11
    Mazda Maniac. lovmyrx7's Avatar
    11 MS3, 12 MZ3 Skyactiv (wifes)
    Join Date
    May 2009
    Location
    Abilene, TX
    Posts
    199
    Have your window all the way up. Hold the switch down, when it reaches the bottom, continue holding for three seconds. After holding for three seconds, hold the switch up. Once it reaches the top continue holding for 3 seconds. You should hear a clicking letting you know the AUTO feature has been programmed.
  12. #12
    Registered Member wreckerboy's Avatar
    Join Date
    Jan 2010
    Posts
    32
    Quote Originally Posted by lovmyrx7 View Post
    ^^^^ This.
    It's even spelled out in the owner's manual, fer chrissake. Mine lost it's programming once about six months ago. I read the damned manual, followed these steps, and have had no more issues.
    Rob
    Hero To The Momentum Challenged
    Director of the East Coast Miata Challenge - sponsored by Phil's Tire Service and Race Day Vinyl
  13. #13
    Registered Member
    2011 Mazda 2 Sport
    Join Date
    Mar 2011
    Location
    Orange County, CA
    Posts
    7
    Pssh... Who needs to read the owners manual to know how to operate the automatic windows?... I guess I do :X...
  14. #14
    Registered Member
    2011 Mazda 2 Sport
    Join Date
    Mar 2011
    Location
    Orange County, CA
    Posts
    7
    Thanks, by the way, lovmyrx7, for the tip.
  15. #15
    Join Date
    May 2009
    Location
    Abilene, TX
    Posts
    199
    Quote Originally Posted by christianpm View Post
    No problem I do what I can.
Similar Threads
  1. WTB: P5/P/MSP '02-'03 Window Regulator - Driver's Side
    By BGR in forum Completed Transactions
    Last Post: 12-06-2008, 11:01 AM
  2. fix driver side window
    By ZoomZoomchic in forum Mazda3 Infotainment
    Last Post: 09-19-2008, 09:22 AM
  3. WTB: Driver Side Window's Control
    By dxaveP5 in forum Completed Transactions
    Last Post: 08-06-2008, 05:34 PM
  4. frozen driver side window
    By tranzformer in forum Protege5
    Last Post: 01-17-2005, 07:38 PM
  5. driver side window rattles
    By johnjay5 in forum Protege5
    Last Post: 09-23-2003, 01:31 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
