Compare auto reliability with reliable results at TrueDelta.com!
Results 1 to 3 of 3
Thread: 04-09 Mz3 Battery question
  1. #1
    Oddly Unaware SC_Mazda3's Avatar
    Donated: $25
    2008 Mazda 3s Hatch 5 spd.
    Join Date
    Feb 2011
    Location
    Fort Mill, South Carolina, United States
    Posts
    37
    I was wondering if anybody knew if companies like Optima or anything made aftermarket batterys for the 3? seeing as how the stock battery is woefully inadaquate....
    Jack of all, Master of none.
  2. #2
    Registered Member chromal's Avatar
    2010 Mazda Mazda3 s Sport 6-spd
    Join Date
    Aug 2010
    Location
    8700ft SW Denver foothills
    Posts
    74
    Why do you say the stock battery is woefully inadequate?
    Car batteries are pretty standardized things. You should be able to pick up one whose specifications are appropriate for your '08 MZ3 5-door just about anywhere general car parts are sold (Wal-Mart, Sears, Autozone, NAPA, etc.) The only "aftermarket" batteries would be ones designed to save weight, e.g.: AGM batts, or Lithium Ion ($$$) or whatever.
  3. #3
    Paramagic icspots's Avatar
    2012 Mazda 5
    Join Date
    Mar 2006
    Location
    Falls Church, VA
    Posts
    1,077
    Also bear in mind that the OEM battery is not a maintenance free battery and requires periodic checking/filling of distilled water. If you're having charging issues with it it's possible that it's run low and actually lost some of it's ability to hold a charge.
    Like chromal said most batteries are pretty much equal (though pretty much any batter you buy in a store will be maintenance free) with the only exceptions being light weight, small, or high capacity like the optimas. If you're running a big stereo system that's really hungry then that's might be up your alley along with possibly a capacitor and if your system is really big a high output alternator.
    So what exactly is inadequate about the stock one?
Similar Threads
  1. Battery question
    By pasadena_commut in forum Protege5
    Last Post: 11-17-2008, 08:10 PM
  2. Question about a battery tie-down...
    By BlueBeast22 in forum Mazdaspeed Protege
    Last Post: 03-03-2007, 01:23 PM
  3. stock battery question
    By mobomelter in forum Mazda3 Infotainment
    Last Post: 09-29-2005, 07:19 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
