Made in USA and Free Shipping on all orders shipped inside the US.
Page 4 of 5 FirstFirst ... 2345 LastLast
Results 46 to 60 of 65
Thread: P5 5th gear swap
  1. #46
    Registered Member aca2983's Avatar
    Join Date
    Jun 2004
    Location
    Alexandria VA
    Posts
    81
    FYI, having visited junkyards 3 times in the past 3 weeks or so, there are lots of Probes, MX-6's, and 626's out there.
    I wish I had the time and a little better facilities since I'd love to do this mod to cut down on highway cruising noise and add another MPG or so. Going to need a clutch in the spring, so would make sense to have it all done at once.
    Bill
    ----------[SIZE="1"]
    '00 Protege ES
    The best kind of car... reliable, and paid-for.
  2. #47
    Huh? What?
    '03 p5 and '89 4Runner; M5 (wife's)
    Join Date
    Sep 2006
    Location
    Aberdeen, MD
    Posts
    286
    Has anyone looked into suppliers for just the parts (e.g., new) such as dealer part #'s etc?
    i'm all for junkyard diving, but sometimes its nice to just get a new part handed to you.. .especially when we're talking about gears.
    My weekend toy
  3. #48
    Join Date
    Jun 2004
    Location
    Alexandria VA
    Posts
    81
    Quote Originally Posted by RatLabGuy View Post
    I haven't looked in awhile, but you may want to see this thread:
    http://www.mazdas247.com/forum/showt...-5th-Gear-Swap
    Also, I believe there has been a thread on Ecomodder.com, but again I don't have time right now to dig thru it.
    I do recall seeing some part #s. There was an online shop that had just the part as a turnkey kit, but last time I checked the link was no longer valid.
  4. #49
    Registered Member
    03 protege5
    Join Date
    Jan 2012
    Location
    winnipeg mb canada
    Posts
    7
    does anyone have part (mazda)numbers for the two gears required to swap into the p5 trans.i have called the dealer and they want a serial(vin) number before they will bother to look up the prices..probably easier to get the two gears new than hunt for a used trans at a wreacker..any info will help..thanks guys..and i might have a 2.0 ltr engine and 5sp manual trans for sale...thanks
  5. #50
    AFCed Since 8/25/07 Alejo_NIN's Avatar
    RadonElement.Com
    Join Date
    Jun 2005
    Location
    Miami Lakes, FL
    Posts
    4,912
    this vin number is for a 2003 mazda protege5 yellow
    JM1BJ245931136424
    http://www.cars.com/for-sale/vehicle...nal&listType=1
  6. #51
    Registered Member 00bluees's Avatar
    2003 Mazda Protege5
    Join Date
    Feb 2008
    Location
    Barrie, Ontario, Canada.
    Posts
    227
    ^^protege VIN won't work because he is looking for parts that aren't from one.
    Quote Originally Posted by lzrd View Post
    look right at the bottom of the first post, you will find the 5th gear parts no's used from a 626/mx6. a good thread with good details if you ignore the rest of the teardown procedure as the 5th gear swap can be done without removing the tranny as he states in the thread.
    '02 Protege5 5 Speed - Sunlight Silver Metallic. Rotted and Parted out
    '03 Protege5 5 speed - Laser Blue Mica. Sold
    '02 Protege5 Turbo 5 speed - Ugly Red. Parting out
    '07 Mazda5 GS 5 Speed - Strato Blue Mica.
  7. #52
    Registered Member hat1018's Avatar
    2003 Protege5, 2006 Mazda3, 2015 CX5
    Join Date
    Mar 2010
    Location
    Perrysville, Ohio
    Posts
    4,349
    Quote Originally Posted by hat1018 View Post
    So any of these 2.0 trannies will bolt right up? Are all of the gears taller or just fifth?
    Has anyone just swapped their tranny out for a Probe, MX6, 626 tranny for taller gears? From the small amount of research I have done I am finding out that the gearing for 3rd, 4th, and 5th are taller on some of the other trannies. I really want to try to drop the RPM's at highway speeds (or more) and want to make a change as easy as possible. If another G series trans will bolt up that would be ideal.
  8. #53
    mazdavangelist MazdaSpeeder's Avatar
    Protege5 (5-spd)
    Join Date
    May 2007
    Location
    Naptown, 46256
    Posts
    2,728
    Just switching out the 5th gear would be easier if all you're looking to do is get a taller 5th gear...it can be done without even pulling the tranny.
    Alpine Head Unit & Pioneer Speakers - MSP Radio Pocket - SLS Gauge Rings - Greddy Weighted Shift Knob - Momo EBrake
    35% Front, 25% Rear Tint - DDM 4300K HIDs - Wipac Fogs - Stoptech Pads - DRT Slotted Rotors - Optima Red Top
    NGK Long-Reach Plugs - 1.8L Coil Packs - Fiamm Low-Tone Horn - MP3 ECU -
    RR Racing UDP - Simota Twin Charger CAI - Magnaflow Cat-Back
    SLS Midpipe - Tsudo Header -
    Corksport Exhaust Hangers - AWR & RR Racing Inserts - Kartboy SS & Bushings - Sumitomo HTR+ 215/40/16
  9. #54
    Registered Member
    2002 Protege5
    Join Date
    Dec 2007
    Location
    Decatur IL
    Posts
    698
    Quote Originally Posted by 00bluees View Post
    I'm confused. That's a good thread, but it refers to the second, thicker layer of gears in the end housing as fifth. What is the function of the outermost pair of gears under the end cap, since reverse is in the main case?
    02 Protege5 - Vivid Yellow - 245K mi
    flywheel, clutch, UR pulley, Injen, OBX, MagnaFlow, Hella fogs, Pioneer head, sub, & 6x9s. On my 7th Mazda!
  10. #55
    Join Date
    Mar 2010
    Location
    Perrysville, Ohio
    Posts
    4,349
    Quote Originally Posted by MazdaSpeeder View Post
    Actually I wouldn't mind having taller 3rd, 4th, and 5th gears. It would make for less shifting during in town driving. If I get a complete tranny I could just swap it, right?
  11. #56
    Protege5 (5-spd)
    Join Date
    May 2007
    Location
    Naptown, 46256
    Posts
    2,728
    I personally wouldn't want taller 3rd and 4th gears...I never cruise in those gears. They are gears I use when I am getting up to speed, and making them taller is going to hamper acceleration. My car (and our mods are surely different so this may not be the case for you) pulls really nicely in 3rd and 4th, and I wouldn't want to change that for maybe 1/2 mpg. Unless you spend an inordinate amount of time in 3rd and 4th, your fuel savings will be minimal.
    I don't know about transmission compatibility (there's some stuff listed earlier in this thread). I haven't ever heard that some of the other transmissions have taller 3rd and 4th gears, but I haven't done the research either.
  12. #57
    Join Date
    Mar 2010
    Location
    Perrysville, Ohio
    Posts
    4,349
    I was poking around on protegefaq.net. I only compared some numbers and I am not totaly sure of what I am looking at/for, so I am only speculating.
  13. #58
    MP5 Love jowens727's Avatar
    03 Red MP5 - Sold
    Join Date
    Sep 2011
    Location
    Tampa, FL
    Posts
    129
    subbin
  14. #59
    RadonElement.Com
    Join Date
    Jun 2005
    Location
    Miami Lakes, FL
    Posts
    4,912
    that's fith gear? lol...
    i always thought that was something else...
  15. #60
    Registered Member
    Join Date
    Jun 2006
    Posts
    663
    Not in here a lot anymore, but just saw this. Look up the Malaysian guy with the turbocharged Ford Tierra. KasmanK, I think was his handle. They only sold the FS-DE there with the four-speed automatic, so when he turbocharged his car, he swapped the box out completely for a 626 box. Worked just fine for him. Gives you the longer fifth and a longer final drive, so all gears are effectively longer.
Similar Threads
  1. GTX gear swap project (25+ pics)
    By 505zoom in forum Pics & Builds
    Last Post: 03-01-2010, 10:53 PM
  2. NSN Motorsport 5th Gear Swap!!
    By Maz2001MP in forum Completed Transactions
    Last Post: 01-06-2010, 01:34 PM
  3. 5th Gear Swap from NSN - Anyone Tried This?
    By MyZmZm in forum Mazda Protege
    Last Post: 06-03-2008, 06:09 PM
  4. 5 gear swap
    By noob2protege5 in forum Protege5
    Last Post: 04-06-2007, 01:13 PM
  5. NSN 5th gear swap?
    By Fasta76 in forum Protege5
    Last Post: 03-01-2007, 03:46 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
