04spoondc5
- 2001 mazda protege mp3
I have a few questions that came up during this project. I came across this article on protegefaq because i was trying to figure out where these FS9 cams came from. when i got my FS-ZE i opened the valve cover up to find both intake and exhaust cams were marked FS9. The swap is up and running, engine runs great, idles at 1,000 rpms. what is my cheapest choice for engine management to really get the full potential out of these cams and high compression pistons. the mp3 ecu seems to still run the motor pretty strong, but id like to make as much power as this motor has to offer.
3rd Generations:
If you are talking about aftermarket cams, then no, none are available.
Don't give your hopes up however. If you own a car with a 1.8 or 2.0 liter
engine, you can get a factory intake cam from the JDM FS-ZE engine (which
has a lift of .341 and the duration 210 @.050). A short run of MazdaSpeed
exhaust cams was also recently made available for that engine and has a lift of
.341, and the duration of 210 @.050. The early version of the MazdaSpeed
exhaust cam (FS9P-12-440) supposedly performs better (by about 1-1.5%
@6000rpm) than the revised version. A TSB was issued in Japan concerning
stalling/idling issues under cold engine and/or cold weather situations and thus
the exhaust cam timing had to be reduced slightly in order to decrease over-
lap from 17.5 to 10.5.
Note that the stock intake cam has
lift of .341 and a duration of 198 @.050.
while the stock exhaust cam has
lift of .322 and a duration of 200 @.050.
Part numbers as follows:
FS-ZE intake cam: FSH9-12-420
MazdaSpeed FS-ZE exhaust cam: FS9P-12-440A (discontinued)
Cam gears from Tripoint Racing are also available.
3rd Generations:
