Hello everyone,
I was wondering if someone could point me in the right direction here.
All of a sudden, my brake pedal starts getting lower and lower while I was driving my gf to work, and by the time I got back home, I almost had no more brake left! I mean, I could probably "push" the pedal with two fingers all the way to the end.
Also, If I "pump" my brakes 2 or 3 times, and don't let it release too long, the pedal is back to normal. but as soon as I release it, (or, stop using the brake pedal for maybe 5 seconds, then it's back where there's no resistence in the pedal.).
Prior to this, I did had brake(or caliper) noises coming from the front, but the car would stop on a dime, and I had plan to change pads/ grease the calipers this summer..
Where would you guys start? bleeding? checking vacuum lines?
Any info on steps to be taken would be nice,
thank you very much!
(2003 protege es, 5 speed)
