passenger window wont roll down...
20
it would work every now and then and now its not. all the other windows work i just can't roll down the passenger side from the drivers side door or from the passenger door. I've disconnedted both sides and still no luck. Anyone else have these problems
I suspect the passenger window switch as the drivers combination switch runs through the door switches.
I would guess it's the motor. You should eliminate that possibility by testing the motor with a hot wire going from the battery to the motor connector.
^yeah...you could quickly build a little switch with $5 worth of parts from radio shack...and by pass the factory switching...if the motor works, its a factory switch issue...if not, the motor might be toast...
