The easiest way i found is unbolt the cruise control and move it to the side. disconnect the power cable (12mm) and plug,take the 12mm bolt out from the alt.Then remove the adjustment bracket (14mm) take that out.Then Take the bottom bolt out and pull it up from the top.I had to replace the alt in my 626 and the manual said to take the pass axle out to get it out.But i think this is easier.
