tweety2300
- 2001 mazda protege mp3
Ok so somewhere I have a leak in my brake line or clutch line or it goes through brake fluid rediculously fast. But after I put brake fluid in it a few days ago I've had nothing but problems. It is extremly hard to shift gears half the time it will grind going into 2nd 3rd and 4th with the pedal pushed all the way in. Also unless I pump the pedal a few times I have a really hard time getting it into 1st at a stop the clutch isn't slipping so I don't think its that I'm thinking air in the line or slave cylinder it also kinda creaks when the pedal gets pushed in more than halfway I'm using dot3 brake fluid if that helps the master slave cylinder is about a year old also and it has 135,000 miles any advice on where I should start?
