Changing the Manual Transmission Oil in the MS6
Extra Innings
2006 MS6
Plan on using the Red Line products to do the tranny and differential. My question to the forum is do I need to change any filters, etc. I did not see anything suggesting I would have to do that on the various (to do) threads here and elsewhere.
Extra Innings
No filters to change in the Manual transmission. I'm running MT90 in mine right now, and it is much better than the factory fill.
^this. No filters in a manual tranny, and RedLine is the s***! People have had luck with "Neo" oil as well.
super easy. you need a 23 and 24 mm socket and dont forget the oil pump its definately necessary for the pto. I always go to jegs and get 3 qts of redline mt90 for the trans and 3 qts of redline gl5 75w90 for the pto and rear diff.
Good luck
