I think this has been posted before, but just as a refresher:
I was at a bodyshop a couple days ago and saw a gt in there with the carpet all ripped up and part of the dash out. The technician advised the sunroof drains got clogged and so the water then went into the headliner, dripped down the windshield pillars and into the dash, into the floor area, electronics, everywhere.
He said this is a problem with the cx-9's with a sunroof.
He said at each corner of the sunroof, there are tiny drain holes for water, and if they get clogged, then the above situation is what happens.
To prevent it, open the sunroof, deposit 75 cents into the gas station tire filler hose machine and spray air into these "corners" of the sunroof every once in awhile to use the compressed air to remove any grit/debris blocking the drainholes.
I have no idea if this was a situation where the vehicle was garaged outside, or if it rained with the sunroof open, or what the deal was.
