Anyone out there had any issues with this sensor or code?
CEL came on yesterday for a little while and then went out........ came back on this morning so I dropped by Auto Zone for a free reading.... P0138
Bank 2 Sensor 1
P0138
Rear HO2S circuit high input ON 2 HO2S C, O, R
(See 0102A58 DTC P0138 [L8, LF])
DTC P0138 Rear HO2S circuit high input
DETECTION CONDITION
The PCM monitors the input voltage from the rear HO2S. If the input voltage from the rear HO2S sensor is above 1.2 V for 0.8 s, the PCM determines that circuit input is high.
Diagnostic support note
This is a continuous monitor (HO2S).
The MIL illuminates if the PCM detects the above malfunction condition in two consecutive drive cycles or in one drive cycle while the DTC for the same malfunction has been stored in the PCM.
PENDING CODE is available if the PCM detects the above malfunction condition during the first drive cycle.
FREEZE FRAME DATA is available.
DTC is stored in the PCM memory.
POSSIBLECAUSE
Rear HO2S malfunction
Short to power supply in the wiring harness between rear HO2S terminal A and PCM terminal 2AH
Rear HO2S or PCM terminal is shorted
PCM malfunction
Bank 2 Sensor 1
P0138
DETECTION CONDITION
POSSIBLECAUSE
PCM malfunction
