tweety2300
- 2001 mazda protege mp3
I can't figure this out. While going straight cruising at constant speed it makes a popping noise from front drivers side wheel. It will quiet down if you give it more gas or go away completely. it does go away complety if you hit the brakes even slightly. Its getting worse and quickly. It also goes away when you turn. Anybody got any ideas? I the jerking the tire every way I possibly could and it wouldn't budge. My trans mount is bad as well. Its my dd and I'm starting to get scared to drive it because its getting louder. The wheel bearing was replaced last spring. The steering wheel will also. Kinda "jiggle" going straight and it seems to be louder going slow
