Rear blower not working on 2008 Cx-9 GT
juliensales
2008 Cx-9 GT AWD Galaxy Gray
Has any one experienced an issue with the rear top blower not working on a 2008 Cx-9 GT.
I turn on the rear control and it only blows air from the bottom (floor) blower no matter whether it is on top or bottom.
Any help would be appreciated.
Thank you.
The rear will only blow HOT air out of the bottom vent. It will NOT blow hot air from the top vent. Only AC COLD air will come out the top, no matter what setting.
Try setting the AC to cold and adjust the speed and check the REAR control disable button on your console.
I think that is how "Auto" mode is.
Hot air from bottom vents, and cold from top ones
My 08 I trifled with yesterday... if you have the rear control button selected and lit, turn the knob on the center console (2nd row control) all the way to cold and it starts blowing out the top, turn the knob just a millimeter warmer, and it starts blowing out the bottom. Basically, it seems that unless you want a/c in the 2nd row, it will always blow out the bottom only. Only upon turning it all the way to the left/counterclockwise, will it blow out the top. Very weird.
