If you want the appearance go for it but do not put 17x9 +20 wheels with 205/45/R17 tires on your Protege and expect it to be a handling marvel.
Really not even if you stretch them a tiny bit? I have never run stretched tires, seen plenty of people at drift events though. I thought that maybe a littlewould help the car for drifting.(scratch) Guess not. (shrug)THERE IS NO PERFORMANCE BENEFIT!
I feel the same way. I have 225/50R16's on mine because I chickened out of 245/45R16's. The rear would have been no problem but the front is so close the coilover already I have to use camber bolts to spacer it out a bit.I almost feel like my 225/45/16s have a little stretch to them on my 8" wide FDs. I wish I could fit 245s on the back, but unless I score a deal before summer, I'll be running 225s all around next year.
You're not following this: there is no performance benefit to stretching tires - at least not over a properly setup wheel/tire combination. There will also always be sidewall deformation even if the tires are stretched. A nice stiff sidewall will improve the "responsiveness" of the steering, and while stretching can accomplish this, all that "responsiveness" means nothing if you can't maintain traction. The best way to reduce tire flex is to maintain proper levels of inflaction and use proper tires for the application.yes agreed not peformance but there is no sidewall to roll so handleing is increased. Stiffer ride but i was not even getting into the contact patch. I got a little strech on my rx-8's but not enough to effect it negatively.
I guess I'll put it this way, if stretching really was a performance improvement why is it that no does it in F1, Grand Am, Le Mans, etc?
No i will put it this way so maybe you can fathem something and follow this.....
Running biggers rims if heavier agreed. On most we do agree but your whole performance thing in general....
Ok we will step onto the protege for a second, stock size is a 215/45/17 cool and to run the 8 inch wide 18's easily and remain lowered you run a 215/35/18. So in theroy you got a wider heavier rim yes but you got less sidewall to absorb the road and no less traction (same tread width). You could run a 225 if you wanted but you would need a hell of a roll to run with a nice drop. So why do they not do it on race cars well atleast you got something right with your performance statement. So you can get back on your performance kick but i can vouch that 17's with the same tires as i got on the 18's grip the same just one is a little better feel in the corners. Also with streched tires you have no feed back from the tires so when she goes she lets loose. Now you can go to the saftey issues if you want but for a mild strech it has not been proven to effect it. The crazy ass vw's on the other hand have proven there is a limit.
End result if you get a wider rim and run the same width tire you get a small strech and it will get you a strech look and have its down falls and perks all in one. The results are minimal.
required no. and for them I'm sure some of it is pure 'style points' too... just trying to use it as an example more than anything. for them a narrow breakaway point in traction is actually an advantage, but they're pretty much the only place on earth where that is the case. lol^^^ To that point it isn't even required for drifting. I can take my 160 HP, torque-less wonder out and easily swing the rear end out by entering a corner hot and applying some moderate trail-braking. The stretched tires in drifting came about because someone got the notion that they HAD to produce less traction in low-powered cars to brake loose.
