NEW JBR Sway Bars in Stock & Shipping Now!!
JBR
Authorized Vendor
09' & 2011 MazdaSpeed3
James Barone Racing
Custom Fabrication of Aftermarket Parts & Accessories
JBR 3-Way Adjustable Rear Sway Bars
$195.00 shipping included!! (Domestic Only)
Constructed out of 32mm 4130 Chromoly tubing with 13mm thick solid steel arms, Tig welded inside and out with capped ends.
Powder coated in either Red or Black for ultimate corrosion resistance.
The JBR Sway Bar Kit Includes:
-New Greasable Polyurethane Mounting Bushings & Brackets
-Grease
-Loctite
-2 12mm Lock Washers
-Lifetime Warranty
-Online Installation Instructions
Everything you need to get the job done right with confidence!!
Applications Available:
07'-2011 MAZDASPEED 3
04'-2011 MAZDA 3 Sedan and 5 Door
06'-2011 MAZDA 5
Specifications Simulating 1" of body roll:
Stock Sway Bar setting:
MAZDASPEED 3 is 479 lbs/in
MAZDA 3 & 5 is 228 lbs/in
JBR 3-Way Adjustable Sway Bar Settings:
Stiff setting is 593 lbs/in
Stiffer Setting is 718 lbs/in
Stiffest Setting is 901 lbs/in
Thanks,
Jamie
I'm ready for spring! It's time to get are cars all cleaned up and ready for track season.
Rear motor mounts and lots of other goodies coming soon!!
