DOES ANYBODY READ THE FIRST post anymore? its morimoto retrofits, meaning its a single filament HID's with a electric actuator in the projectors themselves, that moves the cuttoff line higher up thus giving you the Hi beam.
and even if you ignore that. i'm asking for input on how to rewire the lows to stay on. if you dont have any constructive thoughts, why posts at all?
edit: its a MSP its has a three prong headlight harness, 1 black ground, 1 red 12V low beam power, 1 red 12V Hi beam power. when you turn the highs on, the power stops going thru the low beam wire and goes thru the high beam wire, thus 1 flash sequence goes like this: turning off the ballasts, triggering the actuators in the projectors, turning on the ballasts.
and i want to change it so it keeps constant power to lows and just triggers the high beam power wire when i want to
