funkalicious21
- Mazda Protege 5 Turbo
Past:
Current:
Engine Mods: (2.0L Msp Motor Swap 87k)
-12” Slim Fans (2)
-440cc WRX Fuel Injectors
-505 Intake Manifold
-Aeromotive FPR
-ARP Exhaust Studs
-ATX to MTX Engine Harness Swap
-ATP Wastegate
-ATP Turbo Coolant Stainless Steel Lines w/ 10-An Fittings
-AWR Front Motor Mount inserts
-AWR Passenger Side Motor Mount inserts
-AWR Rear Motor Mount inserts
-Forge BOV
-Garret GT2860RS-Disco Potatoe
-Injen CAI
-MAM Straight Water Neck
-MAM Turbo Manifold
-Mazdaspeed Protg Oil Cooler
-Mazdaspeed Protg Bypass Valve
-Mishimoto Aluminum Radiator
-NGK Spark Plugs Wires
-Optima Redtop 35 Battery
-Outlawed Engineering Intake Spacers
-Perrin Fuel Rail
-Pope’s 3” Down Pipe
-Stainless Steel Oil Line
-Turbo Life FMIC
-Vibrant Silver Vacuum Block
Fuel Management Mods:
-Mazdaspeed Protg ECU
-Split Second Fuel Time Controller
Transmission/Drive train/Shifter Mods: (ATX to MTX Swap)
-Mazdaspeed Protg LSD transmission Swap
-Mazdaspeed Protg Flywheel
-Mazdaspeed Protg Axles
-Mazdaspeed Protg Manual Shift Linkage Swap
-Mazdaspeed Protg Light Weight Flywheel
-TWM Short Shifter
-TWM Shift Link Bushings
Exhaust Mods:
-Calleyway J Pipe
-Calleyway S Pipe
-Corksport Hangers
-Thermal R&D 3” Exhaust Cat-Back
Brake Mods:
-ABS Added System, MSP Front And Rear Knuckle and sensor added
-Drilled/Slotted Rotors Front
-Drilled/Slotted Rear Rotors
-Front M6 06-07 big brakes
-Mazdaspeed Protg Rear Brake
-SS Brake Lines
Suspension/Handling Mods:
-AAC Rear Link Kit
-AIX Clunk Fix Kit
-AWR Rear MSP Endlinks
-BC Racing Coilovers (BR Series)
-BC Extended Dampening Cables
-Eibach SPC Camber Bolts
-Ebay Rear Sway Bar for MX-6
-KMR Front Tie Bar
-KMR 4 Point Ladder Brace
-KMR Rear V Brace
-Racing Beat 20mm Rear Sway
-Racing Beat Front 24mm sway
Tires/Rim Mods:
-Blox Extended Lugs
-Blox Extended Studs
-BBS RS 17x9 -13 (Front)
-BBS RS 17x11 +12 (rear)
-Falken 502 205/40/17 (2 Inch Stretch)
-H&R 25mm Spacers Rear
-Hub Centric Rings
-Nankang NS-1 195/40/17
-Rs5 Tenzo 17x7 +42
-Tuner Lungs
-XXR 962 17x9 +35 front
-XXR 962 17x9 +10 Rear
Appearance Mods:
Exterior:
-5% Tint Windows
-AAC Front Bumper Bracket Gap Fix Kit
-Alocade Eyelids
-Custom Retro Fitted Headlights Projectors
-DGM Urethane Front Lip
-ForceFed Single Gauge Steering Column Pod
-Fatlace License Plate Frame
-iSport Carbon Fiber Rear Spoiler Extension Lip
-Latitude Rain-X Wipers
-LED License Plate Light Bulbs
-Mazda6 Rear Wiper Swap
-Shorty Atenna
-Tenon HID Headlight Kit 6K
-Tenon HID Fog Light Kit 3k
Engine:
-Air Diversion Plate
-DGM Engine Cover
-DGM Carbon Fiber Oil Cap Cover
-DGM Carbon Fiber Air Ram Hood
-DGM Valve Cover Brackets
-Engine Semi Wire Tuck
-Engine Dress-up Bolt Kit By HKP05
-ForceFed Wrinkled Black Valve Cover
-Stock Red Strut Bar
Interior:
-Autometer Oil Pressure Guage
-Autometer Boost Guage
-Autometer Wideband
-Carbon Fiber Shift Boot
-Dave-B Cluster Rings
-Dual Pod Gauge Cluster
-HKS Turbo Timer
-Mazdaspeed Protg Shift Knob
-Mazdaspeed Protg Gauge Cluster
-Mazdaspeed Protg Pedals (Clutch, Brakes, and Gas)
-Mazdaspeed Protg Floor Mats
-Mazdaspeed Protg Seats Front/Rear
-Nardi Miata 99-05 Steering Wheel
-Protege5 EL Door Sills
-Protege5 Cargo Net
-Sparco Pedal Covers
Audio/Video:
-Inifnity Basslink Sub/Amp
-Infinity Kappa 6x9 Component Speakers
-Infinity Kappa 6.5 Component Speakers
-Rockford Fosgate P400-4
-Rockford Speaker Cables (sub only)
-Rockford Subwoofer Interconnect RCA
Misc:
-Clarion 2-Way Alarm
-Royal Purple
-MOCC Forum Decal
-Redline MT-90 Manual Transmission Fluid
-Team Pro5 Decal
-Wix Oil Filter
Recognition:
#18 Slammed Member
First Hella-Flushed Protg/Protege5
Pleasanton Auto Show 2nd Place Best Team. (MOCC)
Team Pro5
Waiting to Install:
-ET Performance Crank Case Vaccum Kit
-K1 Technology Rods
-ACL Thrust Washer
-ACL Main Bearings Set
-ACL Rod Bearings Set
Future Mods/Need To Buy:
-ARP Main Studs
-Cosmetic Head Gasket
-Doc B Oil System
-Oil Relocation
-Pope’s Midpipe
-Wiseco Pistons
-Signature Sound Tanks (Coolant, Power Steering, And Oil)
Black = Installed
Blue = Not Installed
Orange = Uninstalled
Current:
-12” Slim Fans (2)
-Aeromotive FPR
-ARP Exhaust Studs
-ATP Wastegate
-Forge BOV
-Injen CAI
-MAM Turbo Manifold
-Perrin Fuel Rail
-Turbo Life FMIC
-TWM Short Shifter
Exhaust Mods:
-Calleyway J Pipe
-Calleyway S Pipe
-Corksport Hangers
Brake Mods:
-SS Brake Lines
-AAC Rear Link Kit
-AIX Clunk Fix Kit
-KMR Front Tie Bar
-KMR Rear V Brace
Tires/Rim Mods:
-Blox Extended Lugs
-Hub Centric Rings
-Rs5 Tenzo 17x7 +42
-Tuner Lungs
Appearance Mods:
Exterior:
-5% Tint Windows
-Alocade Eyelids
-Shorty Atenna
Engine:
-DGM Engine Cover
Interior:
-Autometer Wideband
-HKS Turbo Timer
-Protege5 Cargo Net
Audio/Video:
Misc:
-Royal Purple
-MOCC Forum Decal
-Team Pro5 Decal
-Wix Oil Filter
Recognition:
#18 Slammed Member
Team Pro5
Waiting to Install:
-K1 Technology Rods
-ACL Thrust Washer
-ARP Main Studs
-Doc B Oil System
-Oil Relocation
-Pope’s Midpipe
-Wiseco Pistons
Black = Installed
