Made in USA and Free Shipping on all orders shipped inside the US.
Results 1 to 6 of 6
Thread: if you are intersted in my build as well as the other build..
  1. #1
    Registered Member
    Join Date
    May 2004
    Posts
    163
    http:// forum DOT mazda 6 club DOT com/speed6-engine-drivetrain/231049-pics-my-motor-build DOT html
    I would post the pics here but there are so many pic i just rather give you the link..
    Heres are some teasers though
    BRAKES
    Ported intake and valve cover
    ADVAN RZ wheels 19x8.5
    after junk was out but still full interior
    With junk in car( VIDEO)
    Ported head
    2006 black mica speed6 WORLD FASTEST SPEED6 12.3@110 done 11/28/10 best 60ft 1.71
  2. #2
    Registered Member Coaststarlight's Avatar
    ..::Atenza::..
    Join Date
    Oct 2009
    Location
    SoCal
    Posts
    114
    was This just a regular P&P? do anything to correct the Airflow problem with Cyl.3?
    Looks Great btw!
    Jonathon
    R.I.P. 06 Mazda Atenza 3.0L - Current Car- 06 SPEED6
    -Will be missed much-
  3. #3
    Registered Member
    Join Date
    May 2004
    Posts
    163
    went to the track over the weekend...
    Only was able to make one pass all day will turn the boost up from 19psi to.... looking at 25 psi
    I am car 664
  4. #4
    Registered Member Igve2shtz's Avatar
    2006 Speed6
    Join Date
    Apr 2007
    Location
    Ocean County, NJ
    Posts
    552
    Looks awesome. Are the only mods you have in your signature? I may have to bring my car down for you to work some magic!
    2006 MS6 Velocity Red Mica
    [installed] Cobb AccessPort OTS Stg 1 - Cobb TIP - CP-E Nano - ETS 3.25" TMIC - Forge BPV - CP-E Motor Mount - Denso ITV22 - Corksport 3" Resonated Test Pipe - Corksport CBE - Mazda Turbo TSB - BC Coilovers - Prosport Premium Boost Gauge - Vent Pod - Dashhawk - Audiolink iPod Adapter - Superbrightleds Parking Lights - Lumenitics Ultra White Fog Lights - Stock Wheels - 215/45/18 Pirelli P-Zero All Seasons - EBC RedStuff Brake Pads
    [Bonus parts] CP-E FMIC - HKS BOV - Protege Garage TIP - Work Emotion CR-KAI 18x7.5 Gunmetal
  5. #5
    Registered Member
    mazda speed6
    Join Date
    Dec 2009
    Location
    Alexandria VA
    Posts
    58
    yeah i wonder too cuz how do u expect to run 25psi on the stock map sensor? also just a fyi, its not always cyl #3 i know MAP had examples up of how overflowing theirs was, but its actually cyl#4 that outflows all others sometimes, people just for a long time thought cyl 3 blew cuz of the balance shaft assembly, but then alot of ppl convinced them otherwise once MAPs results were punblished, since running hotter is one thing for a cylinder, but runnng leaner is running hotterx3 so if there is a failure that is much more probable a cause, i personally would want to get some flow numbers if i got a PnP
    Cp-e FMIC, Cp-e CAI and Turbo Inlet, TurboXS BOV/BPV Hyrbid valve, TurboXS race pipe, COBB AP, Tanabe Spring and Whiteline adjustable sway waiting to be installed
    Mount Vernon VA representing!
  6. #6
    Registered Member
    Join Date
    May 2004
    Posts
    163
    Quote Originally Posted by Igve2shtz View Post
    Pretty much oh i have a big maf and flash as well.. i also have a few tricks that i did but nothing major... As far as the porting of the intake when i ported all the intakes i have done i have not cut it open or anything and i have gotten the same HP as those that have had a professional P&P!! bring it on down and lets see what you can get done for you!!!
Similar Threads
  1. Has anyone seen this guy's build?
    By slavrenz in forum Protege5
    Last Post: 07-31-2010, 06:54 PM
  2. MS3 engine build/PTE 5557 build completed
    By Cherryvodka in forum Mazdaspeed3
    Last Post: 04-29-2010, 02:58 PM
  3. my build
    By sevsev in forum Protege5 Builds
    Last Post: 05-16-2007, 12:25 PM
  4. The Build-Up
    By maximumimpact in forum Global
    Last Post: 04-18-2006, 12:30 PM
  5. will they build it?
    By bazooka joe in forum NEMOC
    Last Post: 02-05-2006, 07:21 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
