Team Pro5 Roll Call
Yup your the first! Hey what kind of window visor are those you got? Really like that look
Those came with the car stock. They usually came with the JDM Sport 20 but I guess how they did this edition they just put them on the car. There are a few bits of stuff that look different from the original RSS (Familia S-Wagon) that was the base for the @Navisport. I took them off recently because the one on the driver side started to develop cracks. I think they are JDM as the Sport 20 has it and could quite possibly be sourced from Japan or even Australia. Sadly I won't be putting them back on, however one of my buddies in our crew has taken them to mold them in Carbon Fiber. I could always talk to him and see if he is willing to do a small production run for you guys.
I know you guys may have come across this before as well but a little below is pretty much what my car looked like but I had the visors and the other note worthy aspect is the car came with 22R silver which I know started to come on the CX7.
http://protege323.com/content/23_worldmodels/index.php
Been a member on the forums for a little bit.
Purchased all my MSP conversion bits off here and had them shipped to me.
This is the end result
INTERIOR
- Factory White face gauge dials,
- Factory Side and Rear skirts,
- Factory Fog Lights,
- Factory Nardi air-bag leather steering wheel,
- Factory Cloth Trim,
- Factory Climate control Air Con,
- Factory Power Steering,
- Optional Mazda clear headlight protectors
- Autometer 60mm Phantom Boost gauge with chrome cup
- Autometer 52mm Prosport Narrowband Air Fuel Gauge connected with old Innovate Wideband LC-1 Controller
- Innovate MTX-L 52mm Wideband Controller/Gauge- JVC Double Din DVD/CD/SD deck
- Nokia CK-7W Bluetooth car kit
- Mazdaspeed Protege 2003.5 Gear knob
ENGINE / MECHANICAL RELATED
- Mazdaspeed Protg 2003.5 Factory Turbo Conversion
- 114kw at the wheels on 8psi
- Genuine Garrett GT25 (Ball Bearing) Turbo
- 1999 Mazda 626 with FS 2.0L Intake manifold (without internal butterflies)
- EMS Stinger 4424 v4 Aftermarket Standalone ECU with hand controller – with software and
cabling. Innovate gauge aux. output connected to ecu allowing the ecu to have closed loop fuel control between -20kpa to -90kpa alterin upto 20% of the original map correcting to 14.7 afr.
- 2.0L FS-DE Engine
- 5 Speed G-Series FWD Gearbox
- Mazdaspeed Cast 2.5” Dump
- 2.5" Exhaust made consisting of 2.5" mild steel tubing, 2.5" mandrel bends, 2.5" stainless steel cataylic converter, 2.5” Varex adjustable noise level
stainless steel rear exhaust with wireless remote control
- Mazdaspeed Radiator + Twin Fans
- Mazdaspeed Intercooler + Piping
- Recently reinstalled factory p5 non turbo full size radiator and fans
- Custom FMIC with fabricated 2.5" mandrel steel pipes
(Will add photos when I take some new ones)
- Injen Mazdaspeed Turbo Intake Kit
- Hardrace harden rubber engine mount kit
- Turbosmart Type III Supersonic BOV
- TurboXS Standard manual tee boost controller (need to install a electronic solenoid for my aftermarket ecu to control the boost spike)
SUSPENSION
- BC V1 Coilover Kit
Kit includes front pillow ball camber adjustable top plates, adjustable height approximately
50-60mm from factory standard height, 32 stage damper adjustable shock absorbers front and
rear. Customise spring rates front and rear
- Hardrace front lower control arms with harden rubber bushes, not polyrethane.
- 17” Genuine Mazda 6 Series 1 Luxury Sport Alloy wheels with 205/40/R17 silica tyres
here is a dyno right after the conversion, of my best run with the original butterflied VICS manifold and non butterflied 626 manifold back to back.
This was with a factory p5 non turbo exhaust
Photos from the FMIC.
Ive finally installed the second piece of the mazdaspeed injen intake that hides the pod infront of the passenger wheel arch.
I'll take some better ones, when I get some time to clean the car up
http://www.allitsolutions.net.au/pics/astina gt/fmic/mazdasp20fmic002.JPG
http://www.allitsolutions.net.au/pics/astina gt/fmic/mazdasp20fmic003.JPG
http://www.allitsolutions.net.au/pics/astina gt/fmic/mazdasp20fmic015.JPG
http://www.allitsolutions.net.au/pics/astina gt/fmic/mazdasp20fmic023.JPG
http://www.allitsolutions.net.au/pics/astina gt/fmic/mazdasp20fmic026.JPG
http://www.allitsolutions.net.au/pics/astina gt/fmic/mazdasp20fmic028.JPG
http://www.allitsolutions.net.au/pics/astina gt/fmic/mazdasp20fmic029.JPG
http://www.allitsolutions.net.au/pics/astina gt/fmic/mazdasp20fmic030.JPG
http://www.allitsolutions.net.au/pics/astina gt/fmic/mazdasp20fmic031.JPG
http://www.allitsolutions.net.au/pics/astina gt/fmic/mazdasp20fmic040.JPG
new dyno tune touch up since the fmic installation.
unchanged boost level since old run.
since the original conversion, I have added 2.5" exhaust and 2.5" plumbed fmic.
need to purchase a electronic boost solenoid to have wired in and have the ems control the boost and elimate that 15psi boost spike
wow nice. send me a rhd clip to txt lol so i can convert mines lmao
Savage bj2! How much did you spend on parts and shipping ?
The parts werent that expensive.
I was lucky enough to get all the bits off all the same vehicle with 50k miles.
The ems delivered from the U.S. to me in Sydney was much more than I budgeted.
Then the USDM ecu is not plug and play and different then our locally delivered bj's, so that was another immediate non budgeted cost.
If I had budgeted for all this additional expense, I would of dumped the FS-DE and went immediately to a low km BPT with aftermarket ecu.
With my old bpt conversion in my 2 door laser (aka. escort) I was making over 130kw at the wheels with the same boost, and a much smoother and calmer engine, than my FS-DE.
My only problem is our emission laws prohibit older engines and running gear from being installed into newer model vehicles and street registered.
Name - Marc
Username - marcs_sp20
Location - Ipswich, Queensland, Australia
Basics
Car: 2002 Mazda 323 Astina SP20
Motor: FS-DE (slightly worn :p)
Trans: G-Series 5spd Manual
Owned for: 5 Years
Power:
81.8kw atw - June 2009 - with old exhaust setup
75.1kw atw - March 2010 new intake & exhaust
76.8kw atw - November 2011 - Nothing changed
Mod List:
Engine
AutoExe Carbon Fibre SRI
Bosch Platinum Plus spark plugs
Upgraded Mazdaspeed Protege coilpacks
2.25" mid pipe from cat-back thru to 2" axle back to X-Force Twin Loop Muffler
4pc AWR mount kit
Tein bonnet Struts
Painted cam cover
Brakes, wheels & Suspension
18x7.5" +50 Gen2 MPS3 rims on 215/35/18 tyres
Apexi front Springs - 35mm drop
Pedders Rear Springs - 35mm drop
KYB Front & Rear struts
RDA Slotted front Rotors & pads
AutoExe Rear Strut Brace
Carbing 3pt front strut brace
Interior
D1 Spec Aluminium gearknob
Polished Astina door steps
Painted dash cluster, centre console & window switch panels
Sticker Bombed centre dash peice
Standard seats
Black Leather Gearboot
********** Guage Rings
Carbon Fibre vinyl on centre dash peice
Carbon Fibre vinyl on Pass. Crash pad
Scan Gauge II in cutout steering wheel column
SP20 Nardi Steering wheel (replacement)
Exterior
Black side strip deletion mod
Genuine Autoexe Grille
Mazdaspeed grille badge
Modified Suzuki Swift stubby Antenna
Dark tinted weathershields
Lamin-X gunsmoke foglight tint
Lamin-X gunsmoke headlight tint
Repainted rear badges in Gunmetal Grey
Evil M rear badge
D1 Spec black lightweight wheel nuts
Team Pro5 decals
Carbon Fibre vinyled rear hatch handle
Bumper Clips
Bumper Sag Brackets
Stickerbombed AutoExe Front lip
JDM F&R slimline window visors
Lighting
HID kit: 35w 4300k H7 low beams
T10 SMD licence plate bulbs
T10 SMD/LED parker bulbs
Clear Side Indicators
Chrome headlight indicator Bulbs
Audio
JL Audio 120w 5x7" 2-way front speakers
Pioneer 160w 6" 2-way speakers
Pioneer AVH-P5950DVD single din 7" dvd player
iPod jack - for full functionality from H/U
Aux Jack for Ipod/phone Connection
12" 125wrms Kicker Sub in ported box
Pioneer 4x75wrms 4ch Amp
Pinoeer H/U remote
4guage Sony 4ch amp kit
Bought / In the Works / Waiting to be installed
Sport20 decals
JDM roof racks
Near new rear endlinks
H7R HID bulbs
Valve Cover Gasket
Low Temp Thermostat
Plans
Mishimoto Radiator
FS-ZE Motor :D
Repair bodywork & Detail
Recaro or Mazdaspeed Seats :D
Name= Ryan Le-Nguyen
Screen Name= SilentBarbarian
Color= Sunlight Silver Metallic
Location= Ypsilanti, Michigan
Current modification=
Engine
Injen Cold air intake
Aftermarket header
Aftermarket Exhaust
Interior
Stock except for the weighted globe shift knob
Exterior
17x7 wheels
Tein Coilovers
Replica Front lip with HomeDepot garage seal
HID 6000k I believe
Everything else is purity much stock on the car
Future plans
To fix up the front (You can see that it is crooked)
Fog lights
Deep dished wheels (maybe)
Sucky camera pictures (deadhorse
Latest posts
