Team Pro5 Roll Call
Hung Tran
Funkalicious21
Mica Black
Past:
Current:
Engine Mods: (2.0L Msp Motor Swap 87k)
-12” Slim Fans (2)
-ARP Exhaust Studs
-ATX to MTX Engine Harness Swap
-ATP Wastegate
-AWR Front Motor Mount inserts
-AWR Passenger Side Motor Mount inserts
-AWR Rear Motor Mount inserts
-Forge BOV / HKS SSQV V2 BOV
-Fuel Pressure Regulator
-Garret GT2554R
-Injen Cai
-MAM Turbo Manifold
-Mazdaspeed Protg Oil Cooler
-Mazdaspeed Protg Bypass Valve
-Mishimoto Aluminum Radiator
-NGK Spark Plus Wires
-Perrin Fuel Rail
-Stainless Steel Oil Line
-Turbo Life FMIC
-Vibrant Silver Vacuum Block
Fuel Management Mods:
-Mazdaspeed Protg ECU
-Split Second Fuel Time Controller
Transmission/Drive train/Shifter Mods: (ATX to MTX Swap)
-Mazdaspeed Protg LSD transmission Swap
-Mazdaspeed Protg Flywheel
-Mazdaspeed Protg Axles
-Mazdaspeed Protg Manual Shift Linkage Swap
-Mazdaspeed Protg Light Weight Flywheel
-TWM Short Shifter
-TWM Shift Link Bushings
Exhaust Mods:
-Calleyway J Pipe
-Calleyway S Pipe
-Corksport Hangers
-Thermal R&D 3” Exhaust Cat-Back
Brake Mods:
-Drilled/Slotted Rotors Front
-Drilled/Slotted Rear Rotors
-Front M6 06-07 big brakes
Suspension/Handling Mods:
-AWR Rear MSP Endlinks
-BC Racing Coilovers (BR Series)
-BC Extended Dampening Cables
-Eibach SPC Camber Bolts
-Ebay Rear Sway Bar for MX-6
-KMR Front Tie Bar
-KMR 4 Point Ladder Brace
-KMR Rear V Brace
-Racing Beat 20mm Rear Sway
-Racing Beat Front 24mm sway
Tires/Rim Mods:
-Blox Extended Lugs
-Blox Extended Studs
-Federal ss595 205/40/17 (2 Inch Stretch)
-H&R 25mm Spacers Rear
-Hub Centric Rings
-Nankang NS-1 195/40/17
-Rs5 Tenzo 17x7 +42
-Tuner Lungs
-XXR 962 17x9 +35 front
-XXR 962 17x9 +10 Rear
Appearance Mods:
Exterior:
-5% Tint Windows
-Alocade Eyelids
-Custom Retro Fitted Headlights Projectors
-DGM Urethane Front Lip
-ForceFed Single Gauge Steering Column Pod
-Fatlace License Plate Frame
-iSport Carbon Fiber Rear Spoiler Extension Lip
-Latitude Rain-X Wipers
-LED License Plate Light Bulbs
-Mazda6 Rear Wiper Swap
-Shorty Atenna
-Tenon HID Headlight Kit 6K
-Tenon HID Fog Light Kit 3K
Engine:
-Autometer Oil Pressure Guage
-Autometer Boost Guage
-Autometer Wideband
-Air Diversion Plate
-DGM Engine Cover
-DGM Carbon Fiber Oil Cap Cover
-DGM Carbon Fiber Air Ram Hood
-DGM Valve Cover Brackets
-Engine Semi Wire Tuck
-ForceFed Wrinkled Black Valve Cover
-HKS Turbo Timer
-Stock Red Strut Bar
Interior:
-Carbon Fiber Shift Boot
-Carbon Fiber Trimmed Ash Tray
-DG Carbon Fiber Radio Cover
-DG Carbon Fiber Passenger A-Pillar Cover
-Dave-B Cluster Rings
-Mazdaspeed Protg Shift Knob
-Mazdaspeed Protg Gauge Cluster
-Mazdaspeed Protg Pedals (Clutch, Brakes, and Gas)
-Mazdaspeed Protg Floor Mats
-Mazdaspeed Protg Seats Front/Rear
-Nardi Miata 99-05 Steering Wheel
-Protege5 EL Door Sills
-Protege5 Cargo Net
-Sparco Pedal Covers
Audio/Video:
-Inifnity Basslink Sub/Amp
-Infinity Kappa 6x9 Component Speakers
-Infinity Kappa 6.5 Component Speakers
-Rockford Fosgate P400-4
-Rockford Speaker Cables (sub only)
-Rockford Subwoofer Interconnect RCA
Misc:
-Clarion 2-Way Alarm
-Mobile 1 Fully Synthetic Motor Oil
-MOCC Forum Decal
-Redline MT-90 Manual Transmission Fluid
-Team Pro5 Decal
-Wix Oil Filter
Recognition:
#18 Slammed Member
First Hella-Flushed Protg/Protege5
Pleasanton Auto Show 2nd Place Best Team. (MOCC)
Team Pro5
Future Mods:
-Dual Pod Gauge Cluster
-Optima Redtop 35 Battery
-Oil Relocation
-Pope’s 3” Down Pipe
-SLS Cat-less Mid-Pipe
-SS Brake Lines
Patrick H.
o.g.sk8er
Vivid Yellow
teaser pics. more to follow. :)
Engine/Trans:<o></o>
  • MP3 ECU<o></o>
  • Unorthodox underdrive pulley<o></o>
  • 1sty full grounding kit<o></o>
  • Modded stock air box<o></o>
  • K & N drop in panel filter<o></o>
  • Spec 2 clutch
  • Mazdaspeed 16lb Flywheel<o></o>
  • MAM stainless catless midpipe<o></o>
  • AWR front engine mount<o></o>
  • AWR passenger side insertS
Suspension/Brakes/Wheels:<o></o>
  • BC coilovers -3* front and -2.25* rear<o></o>
  • GT Spec front 4 point ladder bar<o></o>
  • GT Spec front lower tie bar<o></o>
  • GT Spec upper rear strut bar<o></o>
  • GT Spec lower rear reinforcement panel<o></o>
  • GT Spec rear V-Braces<o></o>
  • Racing Beat RSB (MSP)<o></o>
  • Energy Suspension bushings (modded to fit)<o></o>
  • MSP rear subframe<o></o>
  • AWR rear end links<o></o>
  • AWR rear trailing arms<o></o>
  • Rota Subzeros 16 x 7 45 offset in hyper black<o></o>
  • Hankook RS2’s 215/45/16 <o></o>
  • Muteki SR35 neochrome lugs
  • EBC Slotted/Dimpled Rotors
  • Axxis Ultimate front and rear pads
<o></o>
Interior:<o></o>
  • DGM carbon fiber gauge cluster<o></o>
  • DGM carbon fiber dash cover thingy<o></o>
  • Kartboy short shifter<o></o>
  • Kartboy shifter bushings<o></o>
  • 35% rear tint<o></o>
  • LED dash lights<o></o>
<o></o>
Exterior:<o></o>
  • Tinted yellow fogs<o></o>
  • MZ3 antenna<o></o>
  • DDM 6000k hids
Future mods - keep the car running.
Future events - I attend the local meets regularly and might even hit up a few more track days.<o>
<o>
</o></o>
Mazdaspeed P5
Rolly Ng
Tunerpro5
Laser Blue P5
Engine Mod:
MSP Flashed ECU
DIY FMIC
GT2554R BB
Type S BOV
Painted valve cover
Bellon voltage stabilizer
Mazdaspeed grounding kit
FSDET Oil cap
Crankcase breather filter
Blue blox Vacuum block
2-12" Slim Fan
Interior Mod:
7" Widescreen XO Vision Indash DVD
11' Flipdown overhead LCD built in dvd player
Kenwood 2 10' subwoofer
Kenwood 2ch amplifier
Rampage 4ch amplifier
Sony Front speakers
Lanzar Rear speakers
Power Acoustik Cap
Aluminum Gauge Rings
Carbon fiber Handbrake cover
MSP Shift knob
MSP short shifter
Mazdaspeed pedals
Carbon fiber rear view mirror
Weathertech window deflectors
Mazdaspeed carpet
Mazdaspeed door side sill
Exterior Mod:
JDM H7 HID Headlights
2.5" Custom Catless exhaust system
N1 Black/ Carbon fiber muffler
Tein Lowering Springs
Cross Drilled Rotors
Red painted calipers
Tinted tail light
Wheels:
Azul Sprint 5 rims 17X7 +40 (Bronze)
Nankang NS-I tires 215/45/17
Chrome Lugs
Sokudo 17x7 +48 Carbon black
Achilles Sport 215/45/17
Blue Moteki Lugs
Future Mod:
Coil over setup...
Paint headlights
Maui Team Pro5
posting for a friend
Sergie NYT WING
MAZDA 2002 PROTEGE5(mod list not current)
ENGINE MODS
GT28R TURBO
MAZDASPEED INTERCOOLER KIT
HI-BOOST TURBO MANIFOLD
BLITZ BOV
HALTECH ECU
TIAL 38MM WASTE GATE
WEAPON R FMU
MAZDASPEED CAMSHAFT
SR MOTORSPORT UNDJUSTABLE CAM GEARS
WEAPON R ENGINE DAMPANER
WEAPON R RADIATOR RACING FAN
SAMCO RADIATOR HOSE
K&N INTERCOOLER FILTER
GREEDY CATCH CAN
OPTIMA RED TOP BATTERY
OBX TIE BATTERY
OBX WATER REGULATOR
EXTERIOR MODS
CUSTOM PAINT CANDY RED WITH GOLD FLAKES
VIS EVO CARBON FIBER HOOD
Z3 FENDERS
MAZDASPEED CARBON FIVER LIP
DGMOTORSPORT CARBON FIBER GRILL
DGMOTORSPORT CARBON FIBER SIDE SKIRT
DGMOTORSPORT CARBON FIBER REAR BALANCE
CARBON FIVER SIDE MIRRORS
CARBON FIVER WINDOW PANNELS
FUCUS CARBON SHORT ANTENA
CUSTOM 3" STRAIGHT PIPE
TENZO R CARBON FIBER MUFFLER
INTERIOR MODS
SPARCO RACING SEATS
SPARCO HARNESS BELTS
SPARCO RACING PEDDALS
MOMO JET STEARING WHEEL
MOMO HUB ADUPTER
MOMO JET SHIFT NUB
NRG QUICK RELEASE
CARBON FIBER AIR VENT
DGMOTORSPORT CARBON FIBER DASH KIT
BLITZ TURBO TIMER
BLITZ AIR&FUEL CONTROLER
AUTO GAUGE TACOMETER
AUTO GAUGE BOOST GAUGE
CUSTOM CARBON FIBER MATS
CUSTOM HARNESS BAR
ICE
BOSS 7"SCREEN HEAD UNIT
BOSS 12"FLIP DOWN SCREEN
DIRECTED 7"SCREENS
CUSTOM FIBER GLASS REAR COMPARTMENT BOX
ROCKFORD FOSGATE P3 12" SUB
ROCKFORD FOSGATE AMPLIFIER
SUSPENTION
GTSPEC REAR HARNESS BAR
GTSPEC FRONT HARNESS BAR
AWR FRONT AND REAR END LINKS
SKUNK2 COILOVER SPRINGS
WHEELS AND BRAKES
ENKEI RPF1 17" RIMS
FALKEN 17X45X215 TIRES
SSK ALUMINUM FORGED LUG NUTS
BREMBO DRILLED & SLOTTED ROTORS
HAWK PERFORMANCE BRAKE PADS
CarDomain link
http://www.cardomain.com/ride/2435013/2002-mazda-protege5
^^ yea, thats insane! super clean!
Chris, your car is awesome man! :)
well, tried on some new wheels this weekend. may not be everyones style but oh well. lol haters hate on. lol
16x8 002's, Falken 205/40-16's, in silver. dont care if they're played out, I still like em. lol
so, the rear looks like ass right now, but that'll change in due time. this is just the first initial test fitting.
Im not a huge canyon runner like I used to be in my younger years, so this is what prompted the new change...as well as my tax return. lol
people will say the stretched/poke look is just a fad and will be dead soon. well, this has been around since I was a kid so it looks like its not really going anywhere. at least around my area.
I have always liked this look and while its not everyones cup of tea, I understand that. however I do enjoy it very much and will continue to update this thread as I progress.
so, a little info on these wheels fitment:
the front, fit surprisingly well. only rubbed a little at first, then a minor-cant-even-tell-flare-job later no rubbing now. Im sure over a serious dip it might but just driving around I havnt seen any trouble. I will dial in more camber up front, might bring it down a bit more too after I get things the way I want.
the rears rubbed like mad at first. lol I totally expected that too. (duh!) lol
but after again a flare job, it doesnt rub as bad, but yes does still rub. so I have a few ideas on changing that so it wont rub. ;)
the overall diameter compare to my 215/45's in almost an entire inch! so just the wheel install alone I got a small drop as well. lol
however these 002's are heavier than the rotas. so that kinda sucks.
anyway, haters look away, supporters, hope you likey!
http://www.flickr.com/photos/56672470@N04/?saved=1
and a vid my buddy took...
http://www.youtube.com/watch?v=68o3mIjI-Qk&feature=player_embedded
oh, also installed a used RB axleback I pick up cheap. changed the tip and there you go bro. lol
sounds nice. :)
Hi There
i would like to introduce myself,
I'm Sander 23years old and i am from the Netherlands
my forumname is SanderProtege5
a few weeks ago Efren sended me an email if i would like to join Team Pro5
and i said sure why not, because now i am the FIRST in the Netherlands and also the first in Europe (attn)
now a little story about my car
got this car for a few months now and i'm very happy with it, got this car because my older car had broken down with enige problems
here's a list of the mods
EXTERIOR MODS
- 17'' Arospeed rs gt rims with Nankang tyre's
- RVS Protege 5 Mazdaspeed muffler
- bluemica lugnuts 16x
- Erubuni frontlip
- sportive sideskirts
- sportive rearlip
- wrapt the roof gloss black
- wrapt the grill gloss black
- wrapt the frontlogo black
- 8000K Bi xenon
- Protege5 logo on the back
- and some stickers on the rear
- Vmaxx lowerings springs
ENGINE MODS
- Cosmo Cold air intake
- front strut bar
- protege enigecover
- mazdaspeed oilcap
INTERIOR MODS
- kenwood dnx 8220bt 2din headunit
- EL Protege5 door sils
- DG Motorsports Carbon Interior decals
- aluminum medival dead plate
- Composet in the frontdoors ( Rainbow Sax)
- Caliber sub in the trunk
- Power Acoustik STS-6939 6'' x 9'' 3-wayTriaxiaal Speaker
- all windows tinted
Plans
- KW V2 inox coilovers
- Mazda P5 Carbon Rear Wing Lip !!!! must have this one
- rearstrut bar
- Mazda Protege & P5Air Deflector Plate (ADP) carbon
- A-pillar pod
Now some picture's
link the site in the Netherlands
http://www.formule323club.nl/forum/index.php
and a photo from my old car r.i.p
Latest posts
