I know, old thread but would 40+ offset work on a 2010 Touring?
Hi:Listed below, maybe the answers you are looking for: Mazda5-Wheel-Fitment page 16, post #236
Sorry about the sloppy editing.(ughdance)
02-24-2010, 10:29 AM #236
will fit Ford Fusion wheel 40 offset?
Will the 07' oem ford fusion wheels will fit the 5? I think the offset is only 40. with tire 205/60/16. will their be any problem using this wheels? thanks
02-24-2010, 06:40 PM #237
i dont see why not. stock wheels are +52.5, and thats stock tire size.
Thanks.
03-04-2010, 08:33 AM #238
rhayan911 rhayan911 is offline
Posts:would rims with 40 mm offset ok?
Would a rim with 40 mm offset fit the mazda5?
any problem using it?
- plan to use my brother oem wheels from his FORD Fusion. he change to aftermarket rims. bolt pattern and center bore are the same. but the offset is 40mm. just want to know if this will fit? 16 x 6.5. thanks
03-04-2010, 08:42 AM #239
njaremka njaremka is offline
Wiggity-Wack-O-Tack
njar
those "Should" fit fine, as long as there isnt anything weird with the spokes. I have protege ES wheels on our 5 for winter duty, and they fit just fine. the protege rims are 16x6 +50.
03-04-2010, 12:14 PM #240
Jetmech Jetmech is offline
Registered User
Quote Originally Posted by rhayan911 View Post
40mm is a little low for offset and with higher sidewall you might rub. I would arrange a test fit for sure. The rim will stick out of the fender for sure but will depends on rim width as well.
