Tranny fluid leak!!!on mspd6
Pipatec
Hi a few days ago i was installing the fmic and found a leak around the tranny vent. I never change the tranny oil so it wouldn't be over-filled. Any help will be great :)
Pull the fill plug on the tranny (with the car on jackstands and level), and stick your finger in the hole. Is the fluid level up to the brim of the fill hole? Thats where it should be. If its more, it'll leak out some...just let it leak out a bit.
-a
ive asked around, being over wont affect much.. and it cant be too far over because its a basic level full type system... any extra should just flow out.. i swapped all my diff and gear oils to royal purple after finding where the bolts were.. and only check this while the car is jacked LEVEL not jacked on one end.. filling it, while its jacked end up is how it got overfilled in the first place..
