CorkSport.com is MAZDA PERFORMANCE!
Page 1 of 23 12311 ... LastLast
Results 1 to 15 of 334
Thread: MS6 Build Number Thread
  1. #1
    Nip Slip! BoostedSpd6's Avatar
    Donated: $10
    MazdaSpeed 6
    Join Date
    Jul 2007
    Location
    Plant Earth
    Posts
    3,271
    ok guys here's the scoop, everyone knows that there was only a certain amount of MS6's made. Its not Official that we have Build Numbers like the MSP's do. With that said ive done some investigating along with the help of my cousin (hes a cop) and that investigation has led me to think that we indeed do have specific Build Numbers, although it was never made public.
    so heres the format for the responses in this thread, help me figure out if its true!!!! 80% confident that we do have BN's
    Year
    Color
    Last 6 digits of your VIN -- Your Serial or Production Number
    Last 5 digits of your VIN -- Your Build Number -- Specific to the MS6's
    Build Date-- can be found on the inside of your drivers door jam, theres a sticker where it lists your gross vehicle weight, upper left hand corner
    As of 6/26/2010 All information will be posted in this Spread Sheet - Thank you Jenn and Carter for putting this together.
    http://spreadsheets.google.com/pub?k...=0&output=html
    Breaking Down your VIN Number -- A big thank you to boost2dms6 for this information
    Make/Model: (Digits 1-3) This breaks out the vehicle's make, model, and manufacturer.
    Vehicle Features: (Digits 4-8) These digits identify the various features of the specific model — trim specifications, driveline options, etc.
    Verifying #: (Digit 9) Determined through a complex mathematical formula that relates to the other numbers in the VIN; used to verify that the VIN itself is not fake.
    Model Year: (Digit 10) Represents the vehicle's model year, which is not to be confused with the year it was sold or delivered.
    Assembly Plant: (Digit 11) An internal digit that shows where the car was built.
    Sequence Of Model Production: (Digits 12-17) These digits indicate the order in which the vehicle left the assembly line. This is effectively the Production Number
    MS6 Specific Build Number: (Digits 13-17) These Digits are effectivly your Build Number and are unique to the MS6's
    Using an autotrader VIN I figured out:
    JM1GG12L171109207 09207
    JM1 is obviously Japanese Mazda
    GG12L are the features
    1 is the check # and using this site VIN Calculator it verifys that this VIN is indeed real
    7 is the production year which is 2007
    1 is the assembly plant
    109207 would be in fact our Production Number
    09207 would be your specific MS6 Build Number
    posted on 6 crew
    http://www.6crew.com/forum/showthread.php?t=14832
    posted on mazda 6 club -- pretty weak i cant link them over on here.. had about enough of that bullcrap
    http://forum.mazda 6 club.com/mazda6-atenza/237939-ms6-build-number-thread.html#post3285190
  2. #2
    Moderater
    2001 Corvette coupe
    Join Date
    May 2007
    Location
    Hopewell, Virginia
    Posts
    2,572
    You should add build date to the list. Are you going to post this in the other forums as well?
    You guys know this already from the OP but here it goes.
    Qwik6
    2006 MS6
    White Water Pearl
    00604
    Build date: 9/05
    2006 MAZDASPEED6
    FREEKTUNED @ 20PSI // COBB AP V3 // CPE TMIC // COBB SF // PG TIH // DENSO ITV22s // AUTOTECH INTERNALS // SURE TP // MAGNAFLOW CATBACK // JBR OCC // JBR IM SPACER // JBR PASSENGER & TRANNY MOUNT // SURE RMM // H&R SPRINGS // XXR 530 18X8.75 +35 // CAR LED TAILS // CPE REAR DIF MOUNT // TURBINE TECH FRONT DIF MOUNT // CPE TOW HOOK // 35% TINT // 3M DINOC WRAPPED ROOF // AUTOEXE CARBON FIBER BADGELESS GRILL
  3. #3
    Registered Member
    2007 Mazdaspeed 6 GT
    Join Date
    Nov 2009
    Location
    Pasadena, CA
    Posts
    286
    You need the last 5 numbers, not 4...when I was looking for mine I was checking the VINs and it's pretty obvious that they increase up to about 11000 in order. Add the build date as well.
    2007
    Liquid Platinum Metallic
    10403
    Build date: 6/26/07
    Yes, I have one of the last ones, it's about the latest VIN number that I found.
  4. #4
    Donated: $10
    MazdaSpeed 6
    Join Date
    Jul 2007
    Location
    Plant Earth
    Posts
    3,271
    ok ill add that info in.. mines 02717.. so thats good, as long as Taylor's is 00604 were all set..
  5. #5
    Moderater
    2001 Corvette coupe
    Join Date
    May 2007
    Location
    Hopewell, Virginia
    Posts
    2,572
    its a go
  6. #6
    Donated: $10
    MazdaSpeed 6
    Join Date
    Jul 2007
    Location
    Plant Earth
    Posts
    3,271
    Quote Originally Posted by Qwik6 View Post
    its a go
    copy that!!! fucking awesome..
    so ok if this holds true.. i wonder if we can get mazda to make it official and such..
  7. #7
    Donated: $10
    MazdaSpeed 6
    Join Date
    Jul 2007
    Location
    Plant Earth
    Posts
    3,271
    Ebay Listing Finds
    2006
    White Water Pearl GT
    01227
    2006
    Velocity Red Mica
    00672
    2006
    Velocity Red Mica
    04454
    2006
    White Water Pearl Sport
    02515
    2006
    Liquid Platnium Metallic
    03281
    2006
    Black Cherry Mica
    05697
    2006
    Black Cherry Mica GT
    03232
    2006
    07769
    2006
    Black Mica GT
    06484
    Build Date 03/06
  8. #8
    Moderater
    2001 Corvette coupe
    Join Date
    May 2007
    Location
    Hopewell, Virginia
    Posts
    2,572
    This looks promising. Unless an 07 comes up with a lower number than a posted 06.
  9. #9
    Donated: $10
    MazdaSpeed 6
    Join Date
    Jul 2007
    Location
    Plant Earth
    Posts
    3,271
    It is Promising.. this list confirms it
    Autotrader List: i simplified it so it wasent so huge
    2007 2007 2007 2007 2007
    LPM GT VRM BM VRM LPM
    09207 08698 09178 09877 08322
    VRM LPM LPM BM LPM
    08546 10293 09779 08503 09085
    BM GT VRM LPM LPM BM
    08991 08840 08666 09955 09541
    2007 2007 2007 2007
    BM BM VRM LPM
    10563 (New High Number) 08794 08758 08510
    2007 2007 2007 2007
    LPM BM LPM VRM
    10434 08655 09015 08631
    thats just from 1 page on AT for 2007's
    it leads me to conclude that somewhere between car 07769/08332 is the break line between 06/07 models..hopefully by the end of this we can get a closer number.. the new highest PN is 10563
  10. #10
    The Jamaican Sensation JDM-P5's Avatar
    2006 Speed6 GT
    Join Date
    Oct 2005
    Location
    Andrews AFB /// Washington D.C.
    Posts
    5,689
    JDM-P5
    2006
    White Water Pearl
    02615
    Click me-->_SlammedSedanRegime_<--Click me
    -'06 WWP MazdaSpeed6 GT - 'Attack Panda'
    -'07 CWP CX-7 Touring - 'Family Hauler'
    -'91 Miata Turbo SOLD
    -'02 Protege5 SOLD
    -'93 Project MX-6 SOLD
    (attention)
  11. #11
    Donated: $10
    MazdaSpeed 6
    Join Date
    Jul 2007
    Location
    Plant Earth
    Posts
    3,271
    Quote Originally Posted by JDM-P5 View Post
    Where are the PNs found?
    Your last 5 digits of your VIN is your production number.. read the first post dude, its clearly written
  12. #12
    Registered Member KrGsMrNKusinagi's Avatar
    Mazdaspeed 6 GT
    Join Date
    Jan 2010
    Location
    Dallas
    Posts
    704
    Whats that thing underneath your matt on the passenger side.
    Mine says Prime Number then something in Japanese on a plastic Plaque.
    Mines 05/06
    7615 last 4 of my vin
  13. #13
    Registered Member
    Join Date
    May 2009
    Location
    Wytheville, VA
    Posts
    519
    boost2dms6
    2006 MS6
    Titanium Gray II Metallic
    04783
    Build Date: 01/06
  14. #14
    Registered Member
    Join Date
    May 2009
    Location
    Wytheville, VA
    Posts
    519
    Quote Originally Posted by KrGsMrNKusinagi View Post
    Mines 05/06
    Pretty sure that it says frame/chassis number..
  15. #15
    Registered Member
    Join Date
    May 2009
    Location
    Wytheville, VA
    Posts
    519
    Found you a new high number on Autotrader..
    2007
    VRM
    10729
    Also found a closer one to the cut off
    2007
    VRM
    08218
Similar Threads
  1. My TTD build thread
    By sm76 in forum Pics & Builds
    Last Post: 02-06-2013, 12:35 AM
  2. Cym Re-Build Thread
    By IbanezFreak87 in forum Rotary Mazdas
    Last Post: 08-31-2011, 10:50 PM
  3. STX Build Thread
    By 122 Vega in forum Pics & Builds
    Last Post: 04-29-2007, 01:38 PM
  4. Thread Number 1001!!!!
    By Captain KRM P5 in forum Protege5
    Last Post: 08-02-2002, 11:20 AM
  5. Build number???
    By JcsMP3 in forum Mazda MP3
    Last Post: 12-16-2001, 05:50 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
