L
localkineguy
Hi all,
I have a CEL that reads p0302 - cylinder #2 misfire. The guy at Advanced Auto said to just replace the plug. I didn't know which was #2 so I pulled both middle cylinder plugs and checked them. They look like white/grey-tipped which is "normal" according to most sites that I've seen so far. Also, I've just replaced the coils and plugs about 4,000 miles ago.
I was more suspicious of my EGR valve acting up since I had some rough idling lately. I pulled out my EGR valve and saw that it was all carbon'd. I couldn't clean it because the screws holding the assembly together stripped as I tried to loosen them.
bad Symptoms: rough idle
good symptoms: drives fine, just like before CEL. Recently got 33 MPG on the freeway.
Bottom line: What do you guys think I should do? And is it okay for me to make the 6 hr drive back home?
