xDJ DUBx's 94 PZ NA8C
xDJ DUBx
Slammed Thread President
Round 2
For those of you who don't know, I'm Greg and I have a modding problem. I bought this car after going through hell and back on the protege, on 5/15/10. It was bought used from a private seller for 2,800 and she had 169,432 miles on her. My goal for this car is take take it from the high slow stock car is it and make it a flush, slammed, clean, low key, quick, little fun go cart. So it begins!
05/16/10
06/05/10
05/21/11
-Mod List-
Exterior:
Autokonexion V1 Carbon Fiber Fender Flares, Planet Miata Feed Style Fiberglass Side Skirts, Shine Auto RE-Amemiya Style Pro Carbon Fiber Rear Diffuser, Autokonexion V1.5 Carbon Fiber Trunk, Autokonexion Carbon Fiber Finish Panel, Red Out Tail Lights, MazdaFitment.com Green Sticker, Garage Star License Plate Bracket, Rota Grid-V Gloss White 15x8" +0, Muteki SR48 Green Open Ended Lug Nuts, WFC#1991 Green Sticker, Canibeat Green Sticker, Slammed Society Sticker, Fatlace Green Sticker, Boobies Black Sticker, Stance: Nation Form>Function White Sticker, I Never Narc'd On Nobody Sticker, Project-G Hardtop Spoiler, Shorty Antenna, OEM Non-Defroster Hardtop, Turn Signal Intakes, V-LED Amber 1157 24 LED Front Turn Signals/Parking Lights, DDM Tuning 35W 6000k H4 Apexcone Raptor Bi-Xenon HID Kit, Garage Vary Urethane Front Lip, Angry Miata Eyelids, Clear Lens H4 Headlights, 5% Tint, Windshield Wiper Delete, Smoked Front and Rear Side Markers, Socalmazda.net Purple Decal, Four Corner Fender Roll, Shaved Front Badge
Interior:
JDM 150mm Teal Bubble Shift Knob, Bride Gias Gradation Replica Seats, Clutch Safety Switch Bypass, Soft Top Delete, Auto Meter Z-Series Boost Gauge, AEM Uego Wideband, Auto Meter Z-Series Oil Temperature Gauge, V-LED Green 194 Gauge Bulbs, TDR Single Din 3 Gauge Holder Panel, I.L. Motorsport Single Din Cubby Hole, Wink 5 Panel Panoramic Mirror, Sun Visor Delete, Sparco Strada Steering Wheel, NRG Gen 2.5 Green Quick Release, NGR Short Hub, I <3 Boobies Green Bracelet, Sleepy Eye Controller, Illest Mini Olive Sticker, Little Alien, Hellaflush LA Mini Sticker, Boss Frog Seatbelt Adapters, Hard Dog Hard Core Double Diagonal Hard Top M2 Roll Bar
Stereo:
Alpine CDA-9857 w/ iPod Connection, Glove Box Radio Mount
Performance:
Falken Azenis RT-615K 205/50 Tires, Turbo Oil Restrictor, Turbosmart Black Manual Boost Controller, BEGi S3 GT2860RS Turbo Kit, NGR Type S Blow Off Valve, Flyin Miata Dual Feed Fuel Rail, Denso 450cc Fuel Injectors, Enthuza 2.75" Resonated Test Pipe, MegaSquirt Plug-N-Play Standalone, Flyin Miata Stage 1 Clutch, Depowered Steering Rack, Steel Skid Plate, Enthuza 3" Turbo Racer Cat Back Exhaust, Corksport Urethane Exhaust Hangers, Stance GR+ Full Coilovers, Rear Sway Bar Delete, Mazdaspeed Engine Mounts, Motor Mount Spacers, Energy Suspension Differential Mounts, Washer Fluid Reservoir Delete, SPEC Lightweight Flywheel, TDR Stainless Steel Clutch Line
Engine Appearance:
Cam Gear Cut Out, You Like This Sticker, NGK Blue Spark Plug Wires
-Plans-
In The Mail:
To Be Installed:
Being Bought Very Soon: Spacers, Candy Green Powder Coated Cam Gears, Gloss White Powder Coated Valve Cover w/ Cam Gear Cutout, Rebuild Motor
-Future Mods/Wish List-
Exterior:
Chaser GT300 Carbon Fiber Hood, OEM Rear Bumper Replacement, OEM Front Bumper Replacement, Repaint, Pilot Automotive Clear Lens Headlights, Morimoto Mini Bi-Xenon D2S 2.0 Projectors, E46-R Shrouds, Morimoto CCFL 90mm Angel Eyes, Morimoto 3Five 35w Ballasts, Morimoto 3Five 35w 5000k D2H Bulbs, Garage Vary Normal Carbon Fiber Canards, APR Carbon Fiber Mirrors, APR GTC 200 Carbon Fiber Wing
Interior:
Hard Dog Bolt-In Gloss White Harness Bar, Takata Racing 3-Inch 4-Point Driver Harness, Takata Racing 3-Inch 4-Point Passenger Harness, Powdercoat Roll Bar Gloss White, Roll Bar Black Foam Padding, Redline Goods Black Leather w/ Green Stripes and Stitching Shift Boot, NRG Quick Release Black Lock, I.L. Motorsport Center Console, I.L. Motorsport Arm Rest Pad, Roadster Floor Mats, I.L. Motorsport Roadster Sill Plates, BeatRush Rear Strut Bar
Stereo:
Pioneer 6” Component TS-D1720C Front Speakers, Pioneer 10” Shallow Mount TS-SW251 Subwoofer, Pioneer GM Digital Class-D GM-7500M Amplifier, Custom Sub & Amp Box
Performance:
Rebuild Motor, Enthuza 2.75" High Flow Cat, Walbro 190HP Fuel Pump, Flyin Miata Oil Cooler, Mishimoto Aluminum Radiator, Mishimoto Aluminum Fan Shroud, Samco Green Radiator Hoses, 160 Degree Thermostat, Kaaz 1.5 Way LSD, Beatrush Front Strut Bar, DBA High Performance Cross Drilled & Slotted Rotors, Hawk Performance Plus Brake Pads, Goodridge Stainless Steel Brake Lines
Engine Appearance:
Candy Green Powder Coated Cam Gears, Gloss White Powder Coated Valve Cover w/ Cam Gear Cutout, Jet Stream Carbon Fiber Plug Cover, Hood Lift Kit, Satin Black Powder Coated Intake Manifold
Links
Flickr
Tumblr
YouTube
Facebook
oh my jebus ! that came out of nowhere. sickness, did it come with a hardtop? sweet
. the first step is admitting u have a modding problem :p
So you found this one and jumped on it immediately? I take it, this Miata was grannied on the weekends? Or just dirt cheap?
Yeah, pretty much. It was a mix of both. The body is totally straight, clear coat on the trunk is messed up though but no biggie and the interior is great.
i agree run away from the ricelands. Looks like a good score...got the 1.8L as well. Is the car an A package or B package?
I'm hoping DUB is busy pulling the turbo setup. ;)
Dub - Best of luck with the NA. Black will probably be the perfect color. Sort of the antithesis of the White Protege...
Nice car Dub. I'm going to have to get in on the raceland hating though. I vote Koni yellows and ground control sleeves instead.
