Thanks guys.
No, i don't have any pulsing sub problems, it all works great. The sub amp is installed under the drivers seat. One thing to check is make sure the outside case of your sub amp is NOT touching the chassis of your car. It should only be grounded through the ground wire, if the heat sink is touching the Chassis (GND) too then you can end up with some weird ground loops and funny things happen.
