-2002 mazda protege5, stock
-overheating when running for more than 15 minutes on the freeway
-coolant in the coolant reservoir depleted unusually fast and there was back pressure that caused bubbling in the reservoir
-engine bogging, probably due to coolant/water in the cylinders
-the water pump was recently checked by a mechanic and it was okay
because of those symptoms the head gasket was replaced. installed a new Fel-Pro head gasket (https://www.napaonline.com/Search/Detail.aspx?A=FPG26194PT_0238844833&An=599001+102002+50042+2042052) and used Hi-Temp Red RTV Silicone Gasket Maker. A very, very thin layer of the RTV silicone was used. New head bolts were also used.
The head was milled and checked for warping by a machine shop. There was no warping, however, I don't know how much milling was done on the head.
The head bolts were tighten according to specs. Assembly was based on 2002 mazda protege workshop manual (http://web.archive.org/web/20050311003549/protege5.ugly.net/). When attaching the intake manifold back to the head, the gasket may have shifted a little. The intake manifold had to fit over two undetachable bolts that were connected to the head so the head was shifted around until it would fit. I figured that putting the head bolts in would have shifted the gasket properly back in place (any recommendations on this step?). The timing belt was professionally done and the tensioner was replaced. After the engine was fully rebuilt, it started nicely and idled around 1100rpm. After the engine warmed up the idle was rough and the rpm fluctuated between 600-1000. Also, there was water coming out of the tail pipe.
compression test was done and the results:
cylinders 1 and 3- 120
cylinders 2 and 4- 150
I thought that the head bolts might not have been tight enough since the head was milled and not compensated for. An extra 45 degrees of tightening was applied. After reassembly, engine still idled rough.
I also read somewhere online that RTV silicone can be dissolved by gasoline. However, a very very thin layer was used on the head gasket and extra tightening was applied.
Now what?
Now what?
