Hey guys,
I just bought a 2003.5 Mazda Protege Speed at 120,000 miles. The car would stall while coasting in neutral from accelerating in gears 3, 4, or 5. Check engine light comes on. I take it auto zone, reads P0171 Bank 1. I understand the car has too much air coming in from somewhere. I don't think it's my fuel because the car accelerates great, no hesitation. My friend reads it and tests the car. He will let the car decelerate from 3, 4, or 5th gear for about 1 - 2 secs then shift to neutral. The car doesn't die! But the CEL is still on. He tells me that, the air from the turbo that recirculates from the acceleration is being pushed back into the manifold, and when I switch it to neutral really fast, the ECU doesn't account for the extra air, therefore, causing the car to die. However, if I let the air pass into the manifold in gear while having the right amount of fuel, the car won't die after I switch it to neutral. Have been driving around like this and the car seems great. He suggests I take it into performance shop and tell them to modify the ECU so that it compensates for the extra air from the turbo while in neutral. He is suggesting that the fuel injectors are being closed out too earlier form the ECU and is not compensating for the air. Been fine ever since, however, I want to get rid of the CEL. I was wondering if anyone knew weather the CEL and the stall is correlated? If I modify my ECU will the CEL go away? Are they two different problems? Or do I have a vacuum leak? My car won't stall out anymore, but I do have a drop in idle once in a while in neutral. My car doesn't die if I control it as stated above, allowing deceleration before coasting in neutral. Please help? Any suggestions?
