AutoEuphoria
- '08 CPW Mazdaspeed 3
I'm basically done modifying my car at this point, but I want to keep it running until I can sell it. I've been worried lately hearing all the reports of blown engines, and I'm trying to figure out what I can do to take the chances of that happening down to almost nothing. I know that's hard with a modified car, but I figured there has to be one or two main factors causing these engines to let go.
So is it too much boost? Going WOT at too low of an RPM in higher gears (high load)? High revs? Bad tune?
I have a catless DP and MP, FMIC, CAI+turbo inlet, upgraded CDFP, and a Cobb AP (AFRs in the low 11s at WOT and boost set to 16psi via ATR)
I just want to be able to enjoy this car without worrying it's going to blow up...because at this point I'm through putting money into it and I just want to pay it off as quickly as possible...an engine build would obviously screw that idea up pretty good.
So, what's causing these things to let go? Is it as bad (happen as often) as everyone makes it seem like?
