mikebontoft
- 02 Focus SE, 90 626 GT
Like I said, have any of your engines (which I'm assuming are FS-DE) snapped a timing belt or have you guys seen one that has, and bent the valves? If so, how much damage does it usually make anyway? still trying to decide if I should just junk the car or not.
If it helps also, I did a leakdown test (via compression checker hose hooked up to compressed air line, and cams loosened so all valves were "shut") and here were the results:
Cylinder 1: Leaked a good flow through the tail pipe
Cylinder 2: good leakage through intake manifold (when the TB was opened up it went away)
Cylinder 3: again, leaked a good flow through tailpipe
Cylinder 4: same as cylinder 2
What I can infer about this is that the engine went through only 1- 3 strokes, obviously considering only half the exhaust and half the intake valves are bent.
especially if anyone has pictures of it, we all love pictures
Thanks!
Thanks!
