Wheel Size Help
ms6DiGi
Contributor
Mazdaspeed6
I've dug around this forum a bit to find out, but figured someone can probably help me with this in 2 seconds. I am interested in a set of enkei RP-03 wheels for my Mazdaspeed6. I want them in 19". Would these fit? It says that the 19" with 5x114.3 have a width of 8.5". Which might be too wide? Never bought aftermarket wheels before.
There is a full size chart on the website.
enkei.com/rp03.html
BTW I have mazdaspeed coilovers.
Thanks for the help.
So meaning I might just have to roll my fenders/get wheel spacers/adjust my suspension or something? Like, I'll pretty much have to get them and figure out where to go from there, but they can work?
If the offest is between 45-55mm they should work with 225-235mm tyres with some fender rolling. If the offset is outside that range or you want 245s, you may need to pull or flare the arches a bit. Personally, having fit 19s on mine I would recommend 18s, unless you have very good road surfaces and you are not concerned about performance. 19x8.5 rims a likely to add quite a lot of weight.
