Is this caused by a worn out motor mount?
Does not vibrate at all in D and idling, but does in Reverse.
idle speed seems the same either way.
Which motor mount would cause the vibration in reverse only?
BTW - motor was just swapped, so I had all the mounts off. I did not replace them. Expensive little suckers.... Car has 120K miles and is a 2003.
