In Memory of Member 1338
Page 5 of 53 FirstFirst ... 3456715 ... LastLast
Results 61 to 75 of 784
Thread: D Prepared Miata Build
  1. #61
    Yellow Jacket Keno1542's Avatar
    Mazda MP3
    Join Date
    Oct 2005
    Location
    Georgia Tech
    Posts
    1,184
    Thats the one(pictured) most of the continental tire challenge guys run..the rolex guys use the aerocatch ones(they were a pain in the ass, especially when you were in a rush to get the car out on track or something...)
    2001 MP3 - Blue
    1990 Miata Based Exocet - Black and Red
  2. #62
    High Speed Low Drag aMaff's Avatar
    muffled screams
    Protege5 & Protege FS Moderator
    1992 Miata / 2003 Pathfinder
    Join Date
    Sep 2005
    Location
    Lilburn, Ga
    Posts
    18,807
    Ah, gotcha. When I saw them this weekend I knew I'd seen 'em before but a) didn't really take too much notice of them in the past and b) I couldn't place where I'd seen them before. You say the AeroCatches are a pain? I didn't really see that coming lol. Are they just harder to line up or what?
    ~Andrew
    Atlanta Region SCCA
    114 DP
  3. #63
    Mazda MP3
    Join Date
    Oct 2005
    Location
    Georgia Tech
    Posts
    1,184
    They are a little harder to line up when you are setting them up, but sometimes they were just a little finicky if you didnt close the hood exactly right. Nothing a little smack wouldnt fix...but still something else to slow you down when you are thrashing on the car. But for the price difference I dont think they would be worth it for the low speeds of autox.
    The Koni challenge style ones were usually riveted on instead of screwed on like in the pic, that might just have been cause that was easier for the teams than finding the right size screw. Or maybe cause of the vibrations, rivets cant really work themselves loose...
  4. #64
    Slap and Pickle Shadow102's Avatar
    2013 CWP MS3 / 1977 Celica GT
    Join Date
    Jan 2005
    Location
    Atlanta, Ga
    Posts
    6,012
    Quote Originally Posted by aMaff View Post
    CDOC trailer thats always out at Road Atlanta is where i have seen these before i was contemplating it when i had the CF hood on the msp.
  5. #65
    muffled screams
    Join Date
    Sep 2005
    Location
    Lilburn, Ga
    Posts
    18,807
    Quote Originally Posted by Keno1542 View Post
    Yeah, and if they hold up to Continental Tire Challenge speeds, they're fine for me lol
    I was actually thinking about doing that lol. They come with those screws and 'backing plates' for all the screws. I'll probably go that route starting off then if there's ever an issue, just rivet them in.
  6. #66
    /\ My advice /\ apexlater's Avatar
    2000 MR2 Spyder
    Join Date
    Aug 2004
    Location
    Lawrenceville, GA
    Posts
    1,287
    I got mine from Amazon. And I got some nuts/bolts/washers instead of using the sheet metal screws. I'll let you look at them a little closer next time.
    And you just want to copy me with the red.
    Godspeed.
    --Wayne
    2000 MR2-Spyder - STR
    1991 Supra - Daily
  7. #67
    muffled screams
    Join Date
    Sep 2005
    Location
    Lilburn, Ga
    Posts
    18,807
    Quote Originally Posted by apexlater View Post
    Cool, I'd appreciate it. That with some locktite would probably be excellent.
    Well, there were 3 options: Red, Blue and Chrome. I didn't want the chrome, the blue would look weird on the black car, and I like red (because I'm a closet ricer).
    But you know, also because I wanted some of the Ninja to rub off on my car too
  8. #68
    muffled screams
    Join Date
    Sep 2005
    Location
    Lilburn, Ga
    Posts
    18,807
    More parts . The ISC Quick Release came in today. I'm a fan of the design, but the fit & finish leave a bit to be desired. I realize building a Prepared class car, not everything's going to be bolt on, so a little fab work won't kill me, but when something IS supposed to be bolt on, I usually expect it to be. I had to hog out a couple of the holes with a dremmel between the halves that mount the quick-release hex mount to the steering column adapter out because they weren't drilled just right, but now they fit fine.
    The other issue is the bolts that came with the Miata Cage steering wheel adapter aren't the right thread pitch, so I'm going to have to go by the LowesDepot to pick up the right ones. I kinda wish the right ones were just included in with the adapter, but that's not really anyone's fault.
    Anyway, pics of how it'll all go together (it actually looks a lot better than it does in these pics, the flash picked up a crapload of dust from the packing materials that I hadn't cleaned off yet):
    The splined adapter that fits onto the steering column splines, and the stock steering wheel bolt goes over that.
    The hex adapter
    The quick release
    Steering Wheel adapter that mates the quick-release's 3 bolt pattern to a Momo 6 bolt steering wheel
    As I said, I'm fairly impressed with the design, as this is easily, by a long way, the slimmest steering wheel hub / adapter I've seen for the Miata. Most of them move the wheel up at least 3 or 4 inches, plus the depth of the quick release. This one's only about 3/4 inch for the adapter, with the hex bit for the quick release welded right on top of it. The quick release has got like zero play in it that I can find (we'll see how that works once the wheel's on it, but like this, so far no issues). It's a quality piece, it just needs those bolt holes between the steering column and hub adapters lined up properly. Hopefully it's a 1 off issue, but it's a data point.
  9. #69
    Join Date
    Jan 2005
    Location
    Atlanta, Ga
    Posts
    6,012
    dija look into NRG? they have a slim hub and paired with their quick release it only moves the wheel .5-1" away from where the stock position was on the protege. I could still easily touch the control stalks.
  10. #70
    muffled screams
    Join Date
    Sep 2005
    Location
    Lilburn, Ga
    Posts
    18,807
    I didn't really like the design of their quick release, and the quick release + slim hub would have been a lot more expensive than what I ended up with going with the ISC quick release + MiataCage adapter.
  11. #71
    muffled screams
    Join Date
    Sep 2005
    Location
    Lilburn, Ga
    Posts
    18,807
    Well, now that I've got it assembled, I have to say I'm pretty damn happy with it. There's pretty much no play in it, and after playing with it, and the mechanism is really slick. I was able to find the right bolts @ TrueValue, however they were like 1/8" too long, and interfered with the quick release mechanism, so I just hit 'em with a dremel and it works like a charm.
    I'm just excited because a) I got to solve a problem (it's what I do for a living, I get a huge kick out of it), b) it looks cool as shit, and c) I got to MODIFY!!! (and throw some sparks in the garage )
  12. #72
    muffled screams
    Join Date
    Sep 2005
    Location
    Lilburn, Ga
    Posts
    18,807
    So, on the other side of this build:
    S2k sold and 03 Nissan Pathfinder bought with a class III hitch
    Also on order:
    Proportional Brake controller
    7 blade truck-side trailer electrical connection
    2" Ball mount & greaseless ball
    Now to install all of that, and get the trailer on order
    Progress, it's good
  13. #73
    muffled screams
    Join Date
    Sep 2005
    Location
    Lilburn, Ga
    Posts
    18,807
    Wow, haven't updated this in a while... ended up buying a trailer from a friend who was selling his. It's not the prettiest thing, but it's light, hauls great, and will get the job done. And was 1/3 the cost of the one I wanted to buy LOL
    Also: 2 weekends ago Chris (Prodigy) and I (but mostly Chris...) installed the brake controller & wiring harness on the truck. Was a lot of work but we knocked it out
    And today:
    NOW we're getting somewhere
    So they're old. And used. And a medium road race compound. But for a 1st set of slicks, having a tire that can take some abuse isn't a bad thing. After putting a torch and putty knife to a couple of them to get the OPR (Other People's Rubber) off, and some FormulaV tire treatment, they should be a lot more usable
  14. #74
    muffled screams
    Join Date
    Sep 2005
    Location
    Lilburn, Ga
    Posts
    18,807
    I took a couple minutes and crunched some numbers:
    Current wheels: 13.5 lbs (15x7 spec miata wheels)
    Current tires: 24 lbs
    13x7 wheel / tire combo: 23.5 lbs.
    Total weight loss: 14 lbs per corner = 48 lbs of unsprung, rotating mass.
    Think that'll make a difference? I think yes. Very yes.
    Also: just throwing these on will drop the car below 2000 lbs
    Yeah, I'm happy with that
  15. #75
    Join Date
    Jan 2005
    Location
    Atlanta, Ga
    Posts
    6,012
    what are you shooting for whp wise again after all is said and done?
Similar Threads
  1. Cool RC Miata build
    By BoOsTiN in forum Lounge
    Last Post: 08-31-2008, 04:09 PM
  2. Replies: 102
    Last Post: 12-23-2007, 12:46 AM
  3. Street Prepared build
    By xelderx in forum Pics & Builds
    Last Post: 04-29-2007, 08:50 PM
  4. Replies: 7
    Last Post: 03-11-2005, 06:28 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
