brake booster
Tzar177
Contributor
Does our brake booster line have a built in check valve somewhere? I checked the hose but didn't see any check valves
It keep vacum in the brake booster when the engine goes under boost from a turbo. No use for one on a NA engine but a turbo engine with no check valve will end up with no brakes.
Brake booster uses vacum not pressure. You will have a really spongey pedal. Ask me how I found out. The check valve alows the vacum to be drawn but blocks the boost off and keeps it at the vacum all the time. Hopes this helps.
THERE IS A CHECK VALVE IN ALL BRAKE BOOSTERS!
please check before you say incorrect stuff, there is a check valve, u have to feel around for it
its inside the booster line so u can see it unless u feel for it
it helps if u cut off the outer rubber protection layer to find it
