Compare auto reliability with reliable results at TrueDelta.com!
Page 3 of 3 FirstFirst 123
Results 31 to 44 of 44
Thread: How-To: Self Programming Keys and Remote
  1. #31
    Registered Member
    2009 CX9
    Join Date
    Sep 2013
    Location
    NH
    Posts
    1
    I am the original owner of a 2009 CX9 and have two switchblade keys - both start the car but the remote is no longer working. They stopped working probably while still under warranty but because we do not have a reputable Mazda dealer close by I have continued to walk to the driver side door to unlock doors and tailgate. I have tried the programming described above without luck. Any ideas?
  2. #32
    Registered Member
    2009 Mazda Atenza 25S (ex Japan)
    Join Date
    Nov 2013
    Location
    Auckland, NZ
    Posts
    1
    Angry
    We have just purchased a Japanese import 2008 (2009 model) Atenza 25S. It only came with one key/remote which is the blade style key/fob all in one. I have ordered an OBD2 key programmer and some blank keys with immobilizer chips in the hope I can program a 2nd/3rd using this device the same way as Mazda offered to do for NZ$557!!! (as I cannot use the key programming method on the first page without 2x keys to start with).
    However, this is not my issue for now. I have a spare Mazda remote (no key, just a lock/unlock fob) that I want to program to the car (to go with my spare keys when they arrive), and was about to follow the remote programing instructions, however I am stuck at step 2 as this model does not have a power-lock button on the door panel..! (It has the lock rocker next to the door lever, but this cannot be operated with the door open) here is a picture of the same model as mine http://www.tradecarview.com/used_car...?sid=300&pn=14
    Does anyone know the remote programming proceedure for this Japanese domestic market model?
  3. #33
    Registered Member
    '07 Phantom Blue Sport, '62 VW Karmann Ghia vert
    Join Date
    Nov 2013
    Location
    Springfield, MO
    Posts
    23
    Just a quick thank you for this informative how-to. My new-to-me '07 Mazda 5 came with two remotes of which only one worked. I assumed battery issue, but no go! This procedure has resulted in both remotes functioning and now I only need to purchase the key section which is missing from remote #2. Dave
  4. #34
    Registered Member
    Mazda 6
    Join Date
    Oct 2014
    Location
    Suomi
    Posts
    1
    Quote Originally Posted by VRMS6 View Post
    Have seen a few posts asking how to program keys/remotes without going to the dealer. Im posting programming instructions for both. Please note you will need 2 working keys to program them. Remotes it doesnt matter if you have any or not...
    NOTE: this is only for switchblade style and seperate key/remote fob only. Will not work with credit card type keys/remote.
    Remote programming instructions
    Step 1: Open drivers door and leave open.
    Step 2: Lock and unlock the driverís door using the power door lock switch on the door.
    Step 3: Insert key into the ignition.
    Step 4: Turn key to on position and return to off position. (IMPORTANT - use ON position NOT ACC position). Do this 3 times within 10 seconds. Leave key in the ignition.
    Step 5: Open and close the driverís door 3 times. (Door should be left open after this step).
    Step 6
    : ECU should respond by locking and unlocking the doors.
    Step 7: Press any button on remote #1 twice. ECU responds by locking and unlocking the car doors.
    Step 8: Press any button on remote #2 (etc.) twice. Each time the ECU will respond by locking & unlocking the doors.
    Step 9: Remove the key from the ignition and the ECU will respond a final time with a series of door locks and unlocks. You're done!
    Key Programming Instructions
    The timing is critical to this procedure, please read through the entire procedure before attempting.
    Procedure:
    1. Insert one of the pre-programmed transponder keys and turn the ignition to "on", leave on for at least one second (I wait until the red key symbol in the instrument cluster extiinguishes), remove the key from the ignition.
    2. Within 5 seconds insert the second pre-programmed key and turn the ignition to "on" for at least one second but no more than 5 seconds (use the key symbol for this as well) then remove the second key.
    3. within 10 seconds insert the new key in the ignition and turn the ignition to "on", if you are successful the red key symbol will illuminate then extinguish after about a second.
    If you are not successful the red key symbol will flash repeatedly to indicate that you have inserted an invalid key. Remove the key, wait a minute and try it again, it took me a few times to get it perfect and I had done it before.
    Hi!
    I have a 2008 Mazda 6 Sports Wagon 2.0TD. Just bought a new 2 button remote fob because original stopped working. Problem is that I can't get it programmed. I dont' have door lock switch on the drivers door. There's only a central lock knob which lock all the doors including trunck. Please help.
  5. #35
    Banned
    2009,Mazda2
    Join Date
    Nov 2014
    Location
    Landisville
    Posts
    9
    There are many things to keep in Mind while Self Programming Keys and Remote buimportant is that ALL vehicle alarm keyless remotes, fobs, and chipped or transponder*keys MUST BE PROGRAMMED TO A VEHICLE for them to work.*
  6. #36
    Registered Member
    2008 MX-5
    Join Date
    Jun 2015
    Location
    New York
    Posts
    1
    Hey I know it has been years since this thread has been looked at but I have a question. I recently bought a second key for my Miata and I followed the steps to program the buttons on the remote and it worked fine. When I went to program the key so I could start the car I noticed that the way you wrote the instructions imply me having two working keys. Is there a way I can program the new key without 3 keys?
  7. #37
    Registered Member
    2013 CX-9 GT
    Join Date
    Mar 2014
    Location
    IN
    Posts
    2
    Programming your own keys update?
    Hello,
    I have been looking all over through threads about programming the Mazda keys. And finally took the leap and purchase some and had them cut yesterday. I have followed out the procedures from this thread comma quoted below. I have not yet had success but think that it could just be possibly might timing for the procedures or perhaps I got jipped on my transponder keys on eBay.
    I have a 2013 CX9 Grand Touring. Can anyone verify that these procedures still work for my model year?
    Here is specifically what I am trying to do. With the car we received two of the smart key fobs with the key that you can pull out of them as a backup. I've purchased on eBay two standard looking keys by themselves, no remote, but that are supposed to have the transponder chip built-in and they have around a 1/4 -3/8 inch thick plastic part to them so I believe they do have the transponders inside them.
    I want to program these and keep them as backups in the event that we lose one of my original smart key fobs so that I would still have at least two programmed keys.
    Thanks in advance for any help
    Step 6
    Procedure:
  8. #38
    Registered Member
    Mazda 626 LX 2.0L Protege DS 1.8L
    Join Date
    Aug 2016
    Location
    East Tn
    Posts
    1
    Quote Originally Posted by hornsfan10609 View Post
    The remote programming should be posted in the How-To section as it's the same for most Mazdas.
    Also I have the HACK or DO IT YOURSELF KEY PROGRAMMING if you only have "1" key for 1998-2003 626, and other Mazda's I think if it's in those year's it should work check before you do It's at your own RISK. AND it's pretty intense to do but I got it done the first time, which amazed me! Thank's I think this is a first post for me here.
    This Key program is if you only have 1 KEY so may help some. Also for this Key program to work you MUST HAVE A DEALER KEY !!!!!! not a clone type key !!!!!
  9. #39
    Registered Member
    2011 Mazda 6
    Join Date
    Jul 2017
    Location
    TN
    Posts
    1
    One of my transponder key suddenly stopped working.
    Step 6
    Procedure:
    VRMS6,
    Thanks for this tutorial.
    I have a 2011 Mazda 6 which I bought new but is, of course, long out of warranty.
    One of my switchblade transponder keys stopped working today.
    The remote still unlocks and locks the doors, but the security system doesn't recognize that key anymore and won't allow the car to start.
    (This key is my wife's and she rarely drives the car)
    I still have the other key (mine) and it works with no issues.
    Any insight?
    Any way at all to get that transponder working again (without going to the dealer, and without a third working key?)
    Thanks!
    Mark
  10. #40
    Registered Member
    2014 Mazda 6 Touring
    Join Date
    Aug 2013
    Location
    Illinois
    Posts
    119
    Lost my 2016 Mazda6 Keys
    Folks - so I ended up loosing one of my smart keys and using the spare key right now. Question is should I really bother getting a replacement key if I have a functional spare key? The replacement key all inclusive is costing around $325 at the dealership. Additionally, I am worried if the key gets into someone's hands, they can drive it away or steal stuff from the car. Any ideas and suggestions are appreciated.
  11. #41
    Registered Member
    Mazda 6
    Join Date
    Oct 2017
    Location
    Jamaica
    Posts
    2
    I have a 2009 mazda 6 JDM car. I lost the only key that I got when I purchased the car. If I buy 2 keys from ebay, how will I be able to program the new keys?
  12. #42
    Registered Member
    Mazda 6
    Join Date
    Oct 2017
    Location
    Jamaica
    Posts
    2
    VRMS6 can you help me?
  13. #43
    Registered Member
    2012 mazda 6i
    Join Date
    Nov 2017
    Location
    new jersey
    Posts
    1
    Hi, I'm new to this forum. I've never had a key like this before.
    I am also trying to have a spare as the previous owner just had one switchblade. What is the difference between the section on "remote programming" vs "key programming"
    I ask because I want to be clear on whether the "key programming" is done to properly "activate" the transponder chip???
    so if you don't mind please it as clear as you are able - thank you for your help
    Step 6
    Procedure:
  14. #44
    Registered Member
    2015 Mazda 6 Sport
    Join Date
    Dec 2017
    Location
    Milwaukee
    Posts
    1
    Hi. Thank you for the instructions! I recently got a used 2015 Mazda 6 Sport (Manual Transmission), basic model. Are there any instructions on the programming the key? This is not a keyless entry, but was wondering to see if I can program the car/remote to alert for head lights on? My previous car had this, the car will continue to beep if the lights are on (if the engine is off and with the door open).
    Any help is appreciated!
Similar Threads
  1. Remote starter programming help!
    By LENNYB in forum Mazda CX-7
    Last Post: 02-27-2008, 04:44 PM
  2. Programming remote on Mazda 5
    By canadianexpress in forum Mazda5
    Last Post: 02-03-2008, 03:43 AM
  3. Programming Remote
    By dschoemaker in forum Mazda Protege
    Last Post: 01-14-2006, 08:23 PM
  4. remote programming
    By emirem in forum Mazda6 Infotainment
    Last Post: 03-16-2005, 05:54 PM
  5. programming your remote control for mp5
    By Alpinejwl in forum Protege5
    Last Post: 03-06-2005, 02:53 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
