AutoEuphoria
- '08 CPW Mazdaspeed 3
I was attempting to adjust my sway bar a couple of weeks ago, and ran into an issue. Although it's not 100% critical, I would like to resolve it sometime in the near future.
The sway bar endlink has a stud with a recessed hex hole. The idea is that you stick a hex wrench in the middle of the stud to keep it from turning while you loosen the nut holding the sway bar to the endlink. Well, being in Michigan, everything rusts solid within a month of driving in ice and snow, and having gone through an entire winter last year this bolt has, somehow, fused itself to the stud. I sprayed it with PB blaster...WD40...nothing loosened it up. In the process I ended up stripping out that internal hex hole...so now I have no way of keeping the stud from turning as I attempt to break that nut free.
At this point, I'm OK with replacing that endlink...I just have to figure a way to get the nut off without damaging the sway bar. I don't have a welder...I have no welding skills. I also do not have a torch or a cutting wheel. I'd rather figure a way to do this myself than pay someone to do it for me.
Any suggestions?
Any suggestions?
