got 15mm for mine trying to put them on now but the extended studs are not going on. What do i have to do to get them on? they are very hard to get in unlike the stock ones. NEED HELP ASAP!
not hard at all, hammer them out..easy
Push them in as far as they will go, then put a nut (open lug is preferable) on the end and pull it through with that. Should work. How hard were getting the old studs out of the hub?
You sure it'll fit? I'd hate to buy them only to find they don't work...
Positive, but I'll try to snap some pics for the skeptical folks lol... Next time I'm at the shop, I'm pretty sure we could even run 20mm on the stockers, any one have pics of 15mm on rh's installed?
I was more worried about the stock studs not fitting beneath the RH's when using the spacers with new studs build in (Ichiba Version II - I believe)
Where is everyone buying their spacers from...???
For the guys having a hard time swapping studs, they sell 15mm spacers (hubcentric) that bolt up to the stock studs, way easier imo the stock stud stiks out bout 3mm but their are about 5mm pockets on back of the stock racing harts that allowes them to fit. Just an fyi.
