Hi there everyone,
I have an Autometer temp sensor gauge. I was thinking about doing a whole transmission pump and cooler setup from NSN but have scaled back that plan (along with a few others) in terms of modding the car. Now, I just want to somehow place the sensor so it will read the transmission fluid temps (without any pump / cooler setup).
So, my plan is to mod the actual sender (sensor) unit for the gauge into one of the transmission drain plugs so that it will be sitting in the transmission fluid and read the temperature. Attached below are two images - the first is a schematic of the gearbox and the locations of the drain plugs shown in red, and the second is an image of the sender (sensor) itself.
By orion_3582 at 2009-11-24
One of my concerns is whether the sensor will interfere with any of the internal parts of the transmission. Can anyone shed some light on whether there will be a chance of interference between the sender and the moving parts inside the transmission?
Cheers.
Cheers.
