I was a bit clumsy in my removal of an interior panel and broke off a dinky piece of plastic and the plastic snap rivet that holds in the interior panel near the clutch pedal (hand) Does anyone know of a place/person that might have an extra?
Go to your local pick 'n pull. Should be the same piece for all 1st-gen 3s.
you just need the plastic pin part right? just go to home depot man they will have one
I'll try, though there aren't many mazdas to choose from, if any at all... there aren't any dealers for 100 miles :-/
I need that white plastic bracket and whatever fastens that to the sheet metal too. though I could try some epoxy to fix it... thanks for the tip!
this is the part you need #BP4M68AD2A ($2.30) and this is the screw #GJ2168885B ($0.77)
go to onlinemazdaparts.com (http://www.trademotion.com/partlocator/index.cfm?siteid=214264) and search by part number
You can go to http://allmazda.net/login/ to view the pieces (search by part #, then browse to your car) but you have to register on the site first...
