ok thats the one i was looking at anyways but is there any problems in 50/50
Yes, you'll run too rich and get serious backfires fairly often. It is driveable if you like lots of turbo noises and really don't care about performance though.... The OEM BPV works the BEST of anything you can put on your car. There are many people who claim to have had problems with them and MAYBE 1/3 of them did have some type of related problem, but the rest are just blowing "smoke"... I currently run the OEM BPV at 21 psi boost and it works much smoother and faster than the several aftermarket brands I've run... YMMV
Any comments on the forge bpv or su turbosmart bpv?
Didn't try the Turbosmart, but I did the Forge. It is a very good piston/spring BPV, but it has the same issues as all the rest of the piston/spring units. namely their slow reaction due to the weight of the piston, the friction of the piston/bore interface, the inconsistent operation due to lubrication variances and cleanliness, just to name a few. If I went away from the OEM design, I would still run a piston-type, but I prefer the design of the TurboXS recirc BPV. One thing you lose with the OEM version is the big whoosh as the excess manifold pressure is vented. The OEM valve works so quickly that the excess pressure is vented almost immediately and doesn't have time to build up for the big whoosh. This may by why so many think it leaks.
Mine leaked when my boost that used to be spiking at 20 was holding 16 and tapering down to 12-13.
What makes you think it is(was?) leaking? The boost levels you posted here are normal operation depending on temps, load, etc. Been there, done that during my mod process. So many people don't understand that the ECU targets "torque" interpreted as Load, NOT boost levels. If it hits the target load at 12 psi, then that's what you get on your gauge.
The boost-to-load value varies greatly depending on temps, TPS, rpms, gear, etc. The ECU also closes the throttle (regardless of pedal position) at higher rpms to limit load, among other things.
If anyone hasn't already, I recommend they take the time to thoroughly review the information provided by Cobb.(http://forums.cobbtuning.com/forums/forumdisplay.php?f=117)
12-13 psi in a speed 6 is not in the normal operating range. . . At least as far as I know. You obviosly know more about this than I do. All I know is that my boost readings increased when I installed my forge. My car wasn't stock either. I had an intake / test pipe before I changed the bpv.
