HondaEat-R
how do you check the fuel pump and injectors? or do you just have to replace them? also can the stock ecu run a walbro? i'm also getting this code...need to check primary o2 first..
correct me if im wrong but the car at first start runs in closed loop off of preset maps until the 02 warms up and then it switches to open loop....therefore the talk of it being a sensor is not right
