Made in USA and Free Shipping on all orders shipped inside the US.
Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
Thread: How to: install defrost vent gauge pod
  1. #16
    Registered Member
    2010 Mazdaspeed 3
    Join Date
    Aug 2010
    Location
    Tulsa, OK
    Posts
    70
    Quote Originally Posted by special--k View Post
    anyone install this in Gen 2? same thing?
    I am getting this for the gen2. Once I figure it out I will post some pics or instructions.
  2. #17
    Registered Member
    Mazdaspeed3
    Join Date
    Dec 2010
    Location
    Aurora
    Posts
    69
    Any update on Gen2 installs?
  3. #18
    Registered Member
    Mazda, MS3
    Join Date
    Nov 2007
    Location
    Sask, Can
    Posts
    113
    Quote Originally Posted by Rubasu View Post
    you do not need to remove all of that to get the old vent out and the new one installed. you can access the screw holding the vent in but simply removing the the round a/c vent below it. grab inside the vent a bit with your fingers and tug and the vent part will come out of the cup in the dash. then grab the cup and twist it counter clockwise and pull and the cup will come out also as it is simply twist locked into place. then look into where the defrost vent is and at the front edge behind some foam is the screw. it is facing towards the front of the car so you will need to get at it with a small phillips head through the hole where the round vent was at. I installed my boost gauge in that defrost vent pod and wired it up using the switchs on the lower drivers side dash. you can find 12v switched, ground and illumination wires in those switches without having to run wires all the way over to the passanger side fuse box...
    For this install how did you fish the wires through to get it to the switches? Did you still have to remove the under side of the dash?
  4. #19
    Registered Member
    Mazda, MS3
    Join Date
    Nov 2007
    Location
    Sask, Can
    Posts
    113
    Hmm I was able to twist it counter clockwise but it doesn't really pull out afterwards.
  5. #20
    Registered block8head's Avatar
    06 MS6 black mica GT
    Join Date
    May 2007
    Location
    Brockton, MA
    Posts
    455
Similar Threads
  1. HOW TO: Install Boost Gauge into Drivers Vent
    By ElBartoRex in forum Mazda3 How-To
    Last Post: 05-09-2012, 12:49 PM
  2. STRI boost gauge and defrost vent pod
    By boz8029 in forum Completed Transactions
    Last Post: 08-18-2009, 09:46 AM
  3. WTB MS6 Defrost Vent Gauge Pod
    By Jay Davidson in forum Completed Transactions
    Last Post: 08-17-2009, 11:40 AM
  4. WTB MS6 Defrost Vent Gauge Pod
    Last Post: 08-17-2009, 11:01 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
