Been having idling issues, cleaned the EGR valve, seemed to help some, cleaned the IAC solenoid, did not seem to do much though it was dirty. Decided to give seafoam a shot, now the car runs even worse. I followed the instructions in the how to section on all three, they were a lot of help. It sputters throughout acceleration, thought maybe the plugs went bad, changed them with NGK 5464 Iridiums, wires are only a couple of months old same with the coils. The car is an automatic with 127k on it. This is happening with the AC off and in drive. Changing the plugs did not fix it, the CEL flashes 28 times then stays on for a short bit then flashes the same amount again, don't know if that matters. Any thoughts?
