Figured I should just start up a thread. Better here than what did you do to your etc.....I started with your post fish
How the hell could that extremely thin plastic thing make your suspension clunk? I cleaned all mine off and put them all back on. The only thing I'm thinking might be it in the front is that I might have put one of the dots the wrong way, could that cause it? Otherwise I think in the front the endlinks might just need to be adjusted.
I will definitely check the bushings. I plan on a progress in a week or two. need to get new bushings for that anyways.
I also noticed during install that the tokico springs don't seat the same way as the stockers on the rubber mount up top. They're not flat on the top for one thing. I think they ended in a different spot too.
Any insight?
Lift up your car and grab the sway bar and shake it. It may be the bushings. Also check to make sure that the springs are seated properly. My front end clunk on the passenger side ended up being the strut mount bushing which is just a little stupid piece of plastic that goes on top of the strut. It could also be that your endlinks are hitting up against another metal part and just making the sound. Check for any contact marks anywhere underneath there. I know how it is to live with clunks. Even if it's something that doesn't hurt the car at all, it bothers you.
Any insight?
