hey guys,
first of all thank you for all of you input on the other threads similar to this one, they gave me a place to start and a lot of ideas as to what it could be... but after all i am very lost
So i just bought Sunlight Silver #1986, it was the last one sold in colorado, and shes been pretty good to me except for this...
It seems like when the car is good and hot after driving around in normal conditions and boosting a fair amount under full acceleration it hits a wall, it reaches full boost seemingly ok but the motor seems not to react to it at all like its accelerating as if the turbo is not even there and sometimes at about 5500 it seems to be released from whatever this is and accelerate normally until shift or redline. Mods are: Injen CAI, Custom upper IC hard Pipe, Blitz DD BOV, Apex'i Cat back, and boost/ oil pressure guages.
-Boost reading between 5.5 and 7 at full
-Vac reading between 15 and 20 at idle
-Vac line for boost guage tapped at the U on the right side of the intake mani as per the "how to" on this forum
-No CEL
Things ive tried in order (thanks to other posts):
-Hesitation ECU reflash from Mazda performed 2004
-Thought it was fuel related, seafoamed the s*** out of the car via the brake booster plus lucas fuel additive to clean the injectors
-Checked all IC and turbo connections for leaks (none) and cranked everything tighter
-replaced almost all vacuum lines including original boostguage tap which was in the middle of a line between a sensor to what looked like the FPR.. improve BOV performance but otherwise no dice.
-Cleaned air filter really well
-replaced plugs with double platinums (old plugs didnt appeared to be fouled) HELPED A LITTLE
Please help i am so lost and i dont want to keep throwing parts at it or take it in to the stealership. My next attempt was going to be the WGA, but i am unconvinced that this is what it is, doesnt seem to be boosting slower or taking time to build.. but i dont know much about the symptoms... any suggestions or ideas as to what this could be would be greatly appreciated.. i hope i was thorough enough with my description
-No CEL
