In Memory of Member 1338
Results 1 to 5 of 5
Thread: Driver sides door not always unlocking/locking
  1. #1
    Registered Member
    Join Date
    Jul 2009
    Posts
    4
    I first thought it was the alarm, but it seems the same thing will happen when I use the key on the passanger side, sometimes the driver side door wont open and unlock with the rest. Normaly I just need to press lock and unluck again, and the door will pop up, but just now it did not work at all for a couple of mins. Working again now tho, even if it's abit random. Anyone had any problems with this? Faulty wiring, solenoid gone bad?
  2. #2
    Riddle me that! slavrenz's Avatar
    2001 Mazda Protege LX 2.0
    Join Date
    Nov 2008
    Location
    Ames, IA
    Posts
    2,298
    There's this TSB:
    09-012/01
    POWER DOOR LOCK MALFUNCTIONS
    APPLICABLE MODEL(S)/VINS
    All 1999-2001 Protege with VINs lower than JM1 BJ22**** ** 435184.
    DESCRIPTION
    The driver's door lock actuator of some vehicles may be susceptible to internal corrosion. This may cause the door lock actuators to lock and unlock by themselves.
    Customers having this concern should have their vehicle repaired using the following procedure.
    NOTE : If the keyless entry remote was used to unlock the vehicle and the doors are not opened within 2 minutes, the doors will automatically relock.
    REPAIR PROCEDURE
    1. Verify customer concern.
    2. Remove the driver's side door panel according to Workshop Manual (section 07-17 INTERIOR TRIM).
    3. Gently peel back the plastic door screen near the lock area.
    NOTE :Avoid damaging the door screen which may result in water and air leaks. Use care when handling and reinstalling.
    4. Inspect Lot Number on actuator and confirm that it was produced before December 11, 2000. (See illustration.)
    NOTE :Lock assembly removal is not required to view Lot Number.
    ^ If actuator production date is before December 11, 2000, then install a new power door lock actuator according to Workshop Manual (section 09-14 SECURITY AND LOCKS).
    ^ If actuator production date is after December 11, 2000, then continue diagnosis according to Workshop Manual (section 09-14 SECURITY AND LOCKS).
    5. Verify repair.
    It's not quite the same as your issue, but it may be worth looking into.
  3. #3
    Registered Member
    Join Date
    Jul 2009
    Posts
    4
    Quote Originally Posted by slavrenz View Post
    Indeed, if they are subject to corrosion I would guess the problem could show up as periodic mailfunction as well. Guess I need to take a look and see, thanks for the heads up.
  4. #4
    03 Protege LX
    Join Date
    Oct 2007
    Location
    Texas
    Posts
    60
    Same thing has happened to my driver front door as well 03 LX. The lock just didnt work with the rest. However, one day it just started working again after a month of manual locking and unlocking.
  5. #5
    Legal User wagon's Avatar
    Join Date
    Nov 2008
    Location
    Where you live
    Posts
    54
    One of two things,
    either an actuator is beginning to fail; plastic internals -teeth-
    or
    there has become a clearance problem somewhere along the path that either the linkage or the button travels through; tweaked out of alignment or catching or something etc.
Similar Threads
  1. Replacing Door Locking Motor
    By widgit117 in forum Protege5
    Last Post: 07-03-2009, 01:52 AM
  2. Driver door 02 Pro 5
    By starlifter in forum Completed Transactions
    Last Post: 05-02-2009, 10:17 PM
  3. >Door Locking Problem< Need Help
    By BKJT05 in forum Protege5
    Last Post: 05-10-2007, 12:40 PM
  4. Unlocking and Locking Success
    By zul114 in forum Mazda How-To
    Last Post: 10-15-2004, 02:21 PM
  5. Auto Door Locking
    By mraasch in forum Mazdaspeed Protege
    Last Post: 04-21-2004, 01:21 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
