Page 3 of 18 FirstFirst 1234513 ... LastLast
Results 31 to 45 of 265
Thread: How to make Custom Sway Bar End links
  1. #31
    AKA 808P5 HKPRO5's Avatar
    SpeedCircuit AV Rep
    Supercharged Protege5
    Join Date
    Dec 2007
    Location
    Honolulu, Hawaii
    Posts
    6,373
    Yea the male threaded rod looks alot more durable than the female one. Thats another reason why I chose that one.
    Need Parts, Service, or Horsepower?
    Check out S p e e d C i r c u i t . n e t or Email me!
    Need pistons and rods? We stock them!
    Preorder your SpeedCircuit turbo kit today!
    Be sure to check out SpeedCircuit on facebook!
  2. #32
    Slap and Pickle Shadow102's Avatar
    2013 CWP MS3 / 1977 Celica GT
    Join Date
    Jan 2005
    Location
    Atlanta, Ga
    Posts
    6,012
    Ok got my links on today. Lesson learned DO NOT order the smaller size 3/8"-24 is a perfect endlink size. With that being said lowes does not carry nuts in the 5/16"-24 size so these went on without jam nuts but seeing as nothing is twisting i shouldnt have a problem. These had to be mounted in my front bar as my rear bar has to have the 3/8" rodend due to the way it mounts. I figure i can run these until the fail on the front and just get the bigger ones. As you can see in the pics they look a tad small.
    Car feels great though front end seems a little more responsive over the stock rubber and plastic endlinks and i beat on it quite a bit this afternoon and the links have held up fine
    As for my solution for a female center piece, the part i found is not from mcmaster, i ordered it along with all the stuff from mcmaster to make my rear camber link, if it can hold there i dont see any reason for it not to be able to handle an endlink. Pricing wise if you were to build two endlinks with everything i ordered including shipping i would be looking at under $50. Let you guys know how it goes later on this week.
  3. #33
    SpeedCircuit AV Rep
    Join Date
    Dec 2007
    Location
    Honolulu, Hawaii
    Posts
    6,373
    Thank. Looks good too... So far I've had no problems with the links.
  4. #34
    SpeedCircuit AV Rep
    Join Date
    Dec 2007
    Location
    Honolulu, Hawaii
    Posts
    6,373
    How many washers did you use ?
  5. #35
    Join Date
    Jan 2005
    Location
    Atlanta, Ga
    Posts
    6,012
    Quote Originally Posted by 808P5 View Post
    The top I used 4 to space it, the bottom I had to use some spacers only because the stock endlink sits in a bracket that's really wide.
  6. #36
    Will work for boost DeadAir's Avatar
    Donated: 20$
    2003 Protege 5
    Join Date
    Oct 2003
    Location
    Detroit
    Posts
    95
    Wish I'd seen this a couple months ago before I dropped a buttload on new AWR endlinks...
    Good writeup 808 and thanks for the extra info Shadow.
  7. #37
    Registered Member poison's Avatar
    02 P5, manual
    Join Date
    Mar 2009
    Location
    Los Angeles
    Posts
    715
    Killer writeup! Kudo's to you!
  8. #38
    Join Date
    Jan 2005
    Location
    Atlanta, Ga
    Posts
    6,012
    ok guys as promised the refined endlink:
    First off before you say anything yes i know i am missing a jam nut, it was late when i put in the order and my dumb ass forgot the reverse threaded jam nut.
    Anyway as far as parts are concerned, its two male endlinks in the 3/8"-24 threading. However one is right threaded the other is left threaded. You will also need jamnuts of the same threading once again right and left threaded. These can all be found at Mcmaster. Looking about $30 or so for enough to make two endlinks (jam nuts come in boxes of several,usually 25, so you can make multiple endlinks after the initial cost). The center rod is the trick though. It can be found at coleman racing as a shifter rod. The one in the picture is 7" long and it is pre threaded on each end for 3/8"-24 threads, one side right other side left, this allows you to loosen the jam nuts and twist the center sleeve to adjust the endlink on the car. Price is 8.75 per rod and your looking at about $18 for them. So all in all for a set of endlinks plus shipping plus mounting hardware your looking around $60ish
    btw link to coleman racing is http://www.colemanracing.com/store/s...cts.asp?page=8
    I am trying to find out a possible step further and get something with a hex so you can put a wrench on it. I will let everyone know how that turns out.
  9. #39
    SpeedCircuit AV Rep
    Join Date
    Dec 2007
    Location
    Honolulu, Hawaii
    Posts
    6,373
    Looking good man! I decided to take out the rubber o rings and use the washers instead. I recently started cycling to work for exercise so I haven't driven the car yet.
    Shadow do you have any mor driving impressions for the endlinks you recently put on?
  10. #40
    Join Date
    Jan 2005
    Location
    Atlanta, Ga
    Posts
    6,012
    I only drive my 7 once a week or so, drove it about 60miles on monday for work, the front just feels a lot more responsive and not sluggish like it used to.
  11. #41
    Damian Dpwhitehead1's Avatar
    Donated: $25
    LX, MSP 1145
    Join Date
    Jan 2005
    Location
    Owings Mills, Maryland
    Posts
    9,304
    oooh.. i like.. cheaper than any of the shit people are selling now...
    now.. i just need to know what to buy for a lowered msp.. and which shit would be the best... help?
    Be happy!
  12. #42
    Join Date
    Jan 2005
    Location
    Atlanta, Ga
    Posts
    6,012
    Quote Originally Posted by boostdprotegelx View Post
    What's the length on a stock endlink? You can get the center rod as short as 6"
  13. #43
    Donated: $25
    LX, MSP 1145
    Join Date
    Jan 2005
    Location
    Posts
    9,304
    Quote Originally Posted by Shadow102 View Post
    idk. i'm gonna need a set for front, and set for rear..
    the stock endlink is like 10-12 inches i think.
  14. #44
    SpeedCircuit AV Rep
    Join Date
    Dec 2007
    Location
    Honolulu, Hawaii
    Posts
    6,373
    What kind of coilovers are you going to run? The set that i have (the male thread) is 6in plus the ball ends. (for the front)
    BTW im using Ksports....for now....
  15. #45
    Donated: $25
    LX, MSP 1145
    Join Date
    Jan 2005
    Location
    Posts
    9,304
    well for the msp-i'm lowered on megan springs.
    for the lx-i'm looking at a newish set of ksports if i can find the money for them.
Similar Threads
  1. Sway bar end links
    By cbrcrx in forum Protege5
    Last Post: 07-30-2009, 04:18 PM
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
